Flex Trap
What do you say about bathroom sink traps like this?
Jim
Accordion-like drains do not have a smooth interior surface to drain easily and may clog. Recommend replacement with proper tail piece/p-trap.
Thanks Larry, I like it.:cool:
Jim
The sink employs an unapproved, flexible, corrugated drainpipe that will contribute to blockages and it should be replaced by a qualified plumber.
Thanks I like that also Troy.:wink:
Jim
“Insert Location” sink had a temporary flexible corrugated drain pipe installed. This type of drain pipe is prone to frequent clogging. Recommend qualified plumber replace with a standard ridged smooth wall drain pipe and P-trap.
Ditto to what John said…“Temporary” fix to drain problem…replace as soon as possible with proper components.
I prefer this one :wink:
Wonder where I got it from? :slight_smile:
LMAO…I figured something was up from Jeffs post…haha Cool
Jim
Accordion style drains should be tuned every 6 mths to maintain proper flow. :wink:
Bathroom Sink
  • Flexible drain trap piping improperly installed.
  • Recommend professional plumbing repair with replacement of the drain trap assemblies.
