Floor hump
Originally Posted By: dmacy
http://www.nachi.org/bbsystem/usrimages/5/56305_Cleveland_Heights_029_Small.jpg ]
There where numerous cracking at the ceilings and walls at the 1st & 2nd floor…
The wooden main support beam looked ok and one of the columns was rusted at the bottom. The walls appeared to be structurally sound.
[ Image: http://www.nachi.org/bbsystem/usrimages/5/56305_Cleveland_Heights_024_Small.jpg ]
The only concern I had was the large hump in the floor. What do you think?
Dave
Originally Posted By: rbennett
Anyone missing in the homes history??
Originally Posted By: hspinnler
Anyone care to venture into what may be going on?
Originally Posted By: away
Maybe a combination of localized hydraulic pressure and a weak/thin spot in the slab?
Andrew Way
Keystone Residential Inspection Services PLLC
817.441.9598
www.keystoneinspections.com
Originally Posted By: ccoombs
I would recommend further evaluation by an engineer/soils engineer.
There is some type of movement. If the post is directly below the lump I would assume everything settled except for the post. There is the option is that the post moved up. This seems like a less likely option, in my opinion.
Curtis
Originally Posted By: kshepard
When they pour a slab around existing posts, often the area around the posts will be high spots in the slab. If at some point a post is removed the floor winds up with a hump where the post was.
Kent
Originally Posted By: rcloyd
David,
I concur with Curtis. Recommend a structural engineer that utilizes the services of a geo-technical engineer. Something is going on under that slab probably expansive soils.
Regards,
Originally Posted By: rfarruggia
I konw that there is no way to tell, but sometimes in these older houses they would find a really big rock right in the middle of where they are digging the foundation. Maybe it was just too much for them to dig or blast out with their steam shovels or horse-drawn sleds or whatever they had back in those days, and it just wasnt worth the effort just to get a smooth floor in the basement and they just left it there. Eventually, it got a layer of concrete and there you go.
The column in the second picture is definately not from the 20's. Were the columns installed to correct sagging and those wall cracks you saw on the upper floors?
I know all about CYA, but it may be an unnecessary expense to have the buyer spring for a structural engineer and/or a geotechnical engineer to look at a lump of concrete. If the concrete floor is not cracked and does not appear to have been recently repaired, I would lean toward saying something along the lines of "there is a hump in the basement floor" and leave it at that.
Unless the hump is directly over a buried cast iron waste main. Then you need to whip out the old see-snake.
Originally Posted By: pehrenpreis
Hmmm.....
[ Image: CSI ]
Originally Posted By: mboyett
You found Jimmy Hoffa! icon_eek.gif Someone call Geraldo…quick!
Originally Posted By: Jay Moge
how about a repour. that column looks newer than the 20’s. i know thay could have painted, but the paint on the floor could be hiding the repair too. icon_cool.gif
