Fluke IR Camera model TIR4
Barely used IR camera in MINT condition.
Offered to BEST offer.
I paid over $25,000.00
http://www.myflukestore.com/crm_uploads/fluke_tir4ft_thermal_imager-150x150.jpg
Respond to [email protected]
****What’s Included:
  • Heavy-duty carrying case
  • 2 rechargeable battery packs
  • Battery charger
  • AC adapter
  • Video cable
  • 512 MB compact flash card
  • Compact flash card reader
  • USB cable
  • PCMCIA compact flash card reader
  • Neck strap
  • SmartView reporting and analysis software on CD
****The Fluke TiR4-20 IR Flexcam Thermal Imager with IR Fusion is for professionals demanding the best solutions for building diagnostic applications. This Fluke TiR Series model provides the industry’s largest LCD to view on-camera images, augmented with the innovative IR-Fusion™ technology to better pinpoint building problems. IR-Fusion is the overlay of IR and visible images, allowing one to clearly identify critical points within the thermal image.
Use the Fluke TiR series thermal imagers for these and other types of building diagnostics applications:
Roofing Surveys
Detect wet insulation in flat-roof systems quickly and efficiently. Find damaged portions of the roofing structure and repair or replace before the entire roof is contaminated.
Energy Audits
Perform infrared energy audits for residential and commercial applications. Increase the thermal efficiency of a home or building by scanning for thermal heat loss and cool infiltration or ex-filtration , moisture invasion, concrete integrity and heat ventilation problems.
Moisture/Restoration
Accurately detect moisture issues located behind exterior and interior walls, in ceilings or under carpet-covered floors.
Mold Remediation
Control mold by finding unknown sources of moisture that would otherwise go undetected. Infrared scanning is the fastest most efficient way to provide 100% moisture detection coverage
Features:
  • AC Operation
  • Accuracy 2% accuracy
  • Articulating Lens
  • Auto Blending
  • Auto Power Off
  • Color Alarm
  • Custom Boxes/Pointers
  • Custom Field/Text Annotations
  • Detector Size 320 x 240 sensor
  • Detector Type uncooled microbolometer, focal plane array
  • Display 5.0” lcd display
  • Emissivity Correction
  • Flash and Torch Light
  • Focus manual, 1-handed smartfocus
  • Fully Radiometric Images
  • Hot/Cold Point Detection
  • Image Frequency 60hz frequency
  • IR Digital Zoom 2x, 4x, 8x ir digital zoom
  • Laser Pointer
  • Measurement Mode user defined spots/boxes
  • Measurement Mode center point
  • Measurement Mode center box (area, min/max, avg)
  • Memory Type 1gb flash memory
  • Number of Temperature Ranges 1 temperature range
  • On-Board Analysis
  • On-Screen Analysis
  • Optional Lens wide angle
  • Optional Lens telephoto
  • Optional Lenses
  • Palettes 8 color palettes
  • Palettes 8
  • Picture in Picture
  • Programmable AutoCapture
  • Reflected Correction
  • Sleep mode
  • Software
  • Temperature Range °C -20°c to 100°c range
  • Temperature Range °F -4°f to 212°f range
  • Thermal Image
  • Thermal Image Fusion
  • Thermal Sensitivity (NETD) 0.05°c sensitivity
  • Video Output
  • Visible Color Alarms
  • Visual Light Image
  • Windows CE-Based Navigation
Fluke SmartView software is included:
  • Powerful, modular suite of software tools for viewing, annotating, editing and analyzing infrared images.
  • Generate fully customizable and professional-looking reports in a few easy steps.
  • Full support of IR-Fusion® Technology lets you edit images in five viewing modes.
  • Easy to use, yet delivers high-end analysis performance Image viewing and editing
  • Display an array of open images for convenient selection and analysis
  • Scroll across the image to display the temperature at any given point
  • Edit color palettes, reference images, markers, emissivity, and more Extensive annotation possibilities
  • Add annotations (text comments) to images and reports
  • Input information such as locations, category and other notes
  • Reference images can be linked for good/bad and before/after analysis
  • Detailed analysis and total image control
  • Alter the level, span and palette selection to enhance contrast or display detail more effectively
  • Unlimited standard and user-defined analysis markers
  • Five viewing modes allows you to choose the best image presentation for your application needs
  • Simplified report generation
  • Generate professional customized reports fast
  • One-click standardized report generation for a quick results
  • Choice of features including: Before/after, IR plus visible light, annotations, supporting data, graphics and charts
  • Report wizard guides the user through report generation
SmartView software system requirements:
  • Windows® /2000 SP4 with update roll up 1/XP SP2/Vista
  • A web browser for product registration. Internet
  • Explorer 5.0 or newer or Netscape® 5.0 or newer
  • 500 MB available disk space, not counting space requirements for web browser
  • 16-bit color, 800 x 600 resolution video or better
  • Color printer for printing the images
  • CD-ROM drive (for installing SmartView software)
