I would think that a closer study of the ACI documents would help anyone on this subject.
The biggest problem with residential foundations for basement that I see, is that they are continuously done to the minimum standard of the IRC.
Commercial arena will usually have an engineered system.
Not all States provide uniformity in controlling the engineering in residential.
Understanding what is a control joint, wild shrinkage cracking and failures is something I understand from experience, but my recommendations are the same as everyone else. Recommend a structural engineer which is what I said early on.
Poor Larry .
I hope his report is not due yet since his original question has not yet been answered.
The closest we came was when Joe said PV software has good verbage.
How about something like this Foundation cracks of this type and location can and often are a cause for concern. This type of defect should be looked at by a professional engineer when over a 1/4 inch in width. Straight to summery of defects
There are visible cracks in the foundation that need further evaluation by a qualified trades person for determination, evaluation and or corrective repair if required. Since this inspection is visual in nature, it is always recommended that any foundation cracks observed be further evaluated to prevent damage and to insure the integrity of the foundation is kept in tact. The type of crack may ultimately not represent a concern to the integrity of the foundation but we recommend further specialist review for determination of cause and repair options as structural engineers consider any foundation cracks over 1/8th of an inch significant.
You did your job. Informed your clients of a potential costly issue.
Like I said,… it was ‘off the cuff’ so to speak… as I was trying to run out the door. Hopefully no english teachers out there,… I think he gets the gist of how his report could be worded, not verbatim (HOPEFULLY) as I was not there to see all issues that could be conducive to the foundation issues i.e. drainage, grading… etc.
I think that the Acadian French in me failed to point out as to what is the problem.
Here it is:
The god darn concrete wall has failed and the darn contractor that built it is since gone and they did not even install re-bar in the corner.
I would strongly suggest that an Engineer be employed to recommend remedial repairs. At that point will such a Foundation Contractor be notified and advised as to the proper corrective measures and an estimate to the repairs recommended by the said Engineer.
A separation that far would enable you to run a wire vertically in the crack and feel rebar if it is in there.
Most likely you will not find any, because typical and standard corner hook bars are two feet by two feet long #4 in size or a #5 that would be 30" long on both legs.
The only way for rebar on a corner to allow this to happen, would be to actually spall the concrete on each side and pick up some slack as it stretches.
Mr Marcel may indeed be correct. When we`ve seen cracks like this
its been due to lack of/or omission rebar,but also sometimes a footing
for porch etc that can lean-push on wall,sometimes in one spot
sometimes both(where footing meets/is against bsmt wall)
And sometimes the footing may lean/push,slip,drop-settle due to soil underneath
one or both footing edges settling or on new/newer homes, chtt
compaction. Luckily here, it ‘seems’ not much/if any lateral soil pressure
has taken over,caused further problems.Roots can also pose problems
in walls or with differential soil settlement underground,under footings etc.
Could also be possible crack has been there since/right after home was built due to
way this wall or area of wall was backfilled or heavy equipment too close and crack
has not widened much,just saying its possible,especially if they skimped on rebar
in this area of wall. Have seen new/newer homes have just 1 maybe 2 vertical
cracks due way wall was backfilled or heavy equipment or even compaction of the
soil in coming months(though usually not as wide)
Marcel/some others may have also seen a vertical crack in a wall and have the
OPPOSITE wall have same/similar crack…got milk?
Bob, I remember, what happened and why won’t it sell?
You know, I was thinking about that the other night and wondered why you did not keep that up. Your the one that made me start A little on the Commercial side.
Maybe you should revive Peters A little on the Residential Side and continue.
I think members like that and new members learn in the process.
I guess I should Marcel.
I had just started posting here and had been on AR before that where I was getting 70 views within the first 15 minutes at times so I thought there was no interest here.
Still have more pics and should do it again.
Good idea.
Hey Marcel, I think I’ll start posting picture again. Once I finish the garage I’m building, then the finished basement, we will be back at Alan’s job which we will have to install about 150 square of siding, 2500 feet of fascia and soffit and 16 decks. But when I’m done with that we have a 24X32 second story addition to do on lake front property, then a 26X55 second story addition which we are going to convert a ranch into a four bedroom with three baths. We are booked into the end of September and have more work coming in. So much for the recession!
