Garage Door Torsion Spring repair
Is this a legitimate repair? Why not replace the spring
Who the heck knows? We’re not garage door repair professionals were inspectors. Document what you see and move on. Say something about questionable Spring Repair… Ensure repairs were done by a professional by getting documentation or something like that.
I’m no expert, but I sure as hell wouldn’t accept that in my house. If the spring was fatigued enough to break there, it likely has other areas that are fatigued too.
My wife had ours replaced after it broke a few years ago. The upgraded from a single to a double and replaced all the rollers on the door for a couple of hundred bucks. I wouldn’t cheap out with that POS that requires them to tweak the broken coil ends to get it on there.
I’d give the same kind of advice as Joshua.
Torsion springs for garage doors are dangerous and should not be repaired in a red neck fashion.
Needs repair and replacement by a qualified overhead door Company.
Being “think of the worst Marc”, when I viewed those pics I thought of the spring breaking & chopping a person in half…:shock:
Not only dangerous, but stupid.
Ditto what my esteemed colleagues said.
No, that’s not a legitimate garage door repair in my opinion. A torsion spring that’s broken or modified like that has already failed and can’t be trusted. Springs are engineered for a specific cycle life and torque, and once altered, they’re unsafe. The correct fix is to replace the spring with the proper size and rating, not patch it.
Does not look like a legitimate repair for all the reasons already posted. Call it out for a proffessional. Best practice (most expense) is to replace both springs.
I know this is an older thread. Holy crap, I’ve never seen that done before. Turns out they sell those repair blocks on eBay, of course.
FWIW, they have been on the market for years, supposedly as a temporary repair.
Amazon Link
According to Amazon, they are Nylon, or plastic. Lol. Should last a good amount of time then, not subject to moisture damage or anything.
Hard to believe anyone would wind a torsion spring with that goofy thing attached.
The fact that they make a repair kit does not make it safe or right. Just write it up.
Evening, Terrill. Hope to find you well.
Those appear to be overhead garage door Torsion spring repair blocks but I feel the repair is not secure or safe.
From what I read, they are used as a temporary fix for a broken overhead garage door springs.
Observation. Temporary overhead garage door Torsion spring repair blocks.
Recommend a licensed garage door mechanic replace the broken over head garage door spring and adjust the torsion on both overhead springs.
Act upon any recommendations therein.
