Originally Posted By: cbottger
Question??
Had a gas fired water heater producing 120 degree water and cycling on the control. The most remote outlet in this 2600 sq ft home had a water temp of 90 degrees and was a bathroom with single delta faucet control for the shower/tub combo. The kitchen sink was the closest outlet to the water heater and it also had a temp of 90 degrees. The water heater also had a circulating line connected to the drain valve. What was the problem here????
Don't argue with an idiot someone watching may not be able to tell the difference.
