Originally Posted By: swalch This post was automatically imported from our archived forum.
Can flex piping be used to connect the furnace to the gas pipe. I thought it had to be solid piping, but I see it all the time and hear contractors say it is OK.
Mostly what I see is solid piping all the way from the main gas line in the house. Then if they don’t keep it solid the flex pipe is usually about a foot long and goes into the furnace. What do you think?
I'll assume for a moment that you are referring to the appliance connector (a short length of flexible steel tubing connecting the gas piping to the furnace/appliance).
This is allowed in most jurisdictions and recommended by most manufacturers. The flex line should not pass through the appliance cabinet. In some cases, the manufacturer allows it to pass through if protected with a grommet, but the rule of thumb is that it should not pass through the cabinet.
-- Jeff Pope
JPI Home Inspection Service
(661) 212-0738
