GE Heat Pump age
Originally Posted By: rwills
Does anyone have information on deciphering General Electric heat pumps? I have info on most models but can’t find a thing on GE. The model and serial numbers to the one in question are:
M- BWV924G110D0
S- 388580816
I'm guessing that 85' or 92' would be mfg year. Thanks, Bob W
Originally Posted By: dvalley
Robert,
No such number in Prestons.
I see a lot of BW_ _ _ _ _ _ _ _ _ but no match to your model number.
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: jhagarty
of 1985 by the Serial number coding.
M- BWV924G110D0
S- 388580816
Joseph Hagarty
HouseMaster / Main Line, PA
[email protected]
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Originally Posted By: Gary Reecher
M- BWV924G110D0
S- 388580816
look for a BWV724G110D0
7= quick connect fittings
if it was BWV024
0= brazed connections
in BWV.
The closest number I can find is BWB924A-C and BWB924C. Both of these particular units were manufactured in 1980.
David Valley
MAB Member
Thanks guys!
This is the trickiest one I have come across. Ironically, it’s in my own house that I am about to purchase. BW
Originally Posted By: jwilliams4
the size and other information comes from the model number.
Joe Hagerty guessed, but he is correct.
I double checked and model # is definitely - M- BWV924G110D0. I too found it strange that the number doesn’t show up anywhere. I have never had this much of a problem tracking a serial #
Quote:
On almost all manufacturers the date is found in the serial number
You are incorrect, my man.
David Valley
MAB Member
Originally Posted By: mboyett
David,
Why do you say that? My experience and even my ‘cheat sheets’ all refer to the serial number for the date of mfg. The model number of an appliance might be built for several or even many years. What am I missing?
are utilized to check date of manufacture, depending on what heating component you are looking up.
David Valley
MAB Member
David,
You'll notice in your first post that Prestons was of no help,
for whatever reason. Thirty years of experience with HVAC
taught me to rely mostly on the serial number for age and
model number for size. I've always been able to locate this
information and I don't use Prestons. Too frequently, in these
posts concerning equipment age, Prestons has been of no use...
...I've noticed that over the past year or so.
"for
age and efficiency rating, which is exactly what I said.
Serial No = age
Model No = rating
Jae,
Prestons utilizes model numbers only. Not serial numbers...
This is the first time I've ran into this problem (not finding a model number) with Prestons.
For the most part, Prestons does assist in determining the age of manufacture, but I'm just now realizing that it's not a perfect system.
David Valley
MAB Member
Originally Posted By: tallen
I have been very disapointed with Prestons. So much so, that I rarely even bother to open the darn thing.
![icon_mad.gif](upload://j9pysYkUDeHxjgaVCpqL5B8x4z3.gif)
Originally Posted By: kwilliams
jwilliams4 wrote:
David,
Jae - what do you use besides your experience
Michael Boyett referred to them as “cheat-sheets”,
but I never cheat so I call them my "supreme informational
indicator lists"
Besides, G/E was one of my most installed lines of equipment.
thanks
