Bryant Breakers with Cutler-Hammer
Eaton also owns Bryant, so most Bryant breakers will be compatible with Cutler-Hammer panels.
and:
Bryant Circuit Breakers Compatible Replacements
Bryant electrical breakers are no longer available in the market, but Eaton Cutler-hammer breakers make for good substitutes, especially if you use load centers from Bryant.
Since they are officially linked, Eaton or Cutler-hammer breakers can be Bryant circuit breaker cross reference. Bryant used to be a subsidiary of Whitewesting until Cutler-hammer (now Eton) purchased Whitewesting.
https://www.galvinpower.org/what-circuit-breakers-are-compatible-with-bryant/
Even if several brands of circuit breakers fit your breaker panels, you shouldn’t install them in your panel. They may look very similar in appearance, but they probably have several differences like the mounting process, the busbar connection, and more.
All panels and circuit breakers are only perfectly suitable when they come from the same brand.
Even if you can fit another company’s breaker on your panel, its grips may loosen over time. This may cause trouble in your electrical system. It is necessary to replace a circuit breaker in your panel with the same brand to prevent any electrical malfunction.
However, using the same brand still poses another problem: obsolete parts. That said, don’t panic if you face this problem; you don’t need to replace your entire electrical system right away.
Upgrading your electrical system will most definitely cost you a lot of money. You can consult with a professional to determine the most trusted-recommended circuit breaker brand to fit your old load center perfectly.
Moreover, look at your old circuit breaker and see if it is specified as a UL-classified product. Many UL breakers are interchangeable and tested and approved for use with different panels.
Another good thing for a UL-listed breaker is that it was tested under extreme conditions. It ensures that the design meets or exceeds safety standards.
Watch this video made by Circuit Breaker Wholesale. It will provide you with information on why circuit breakers aren’t interchangeable.
See video…scroll down:
