GFCI Receptacle Testing
I’m sure the issue of testing GFCI receptacles (outlets) has been bantered around before, but another topic reminded me of a Mike Holt newsletter article about that so I thought I would share it … icon_wink.gif
http://www.mikeholt.com/news/archive/html/master/How_the_Test_Button_Works_on_a_GFCI_Receptacle_01-5-2002.htm
Bottom line is that I think you have to also push the test button, in addition to checking it out with a decent plug-in tester (ahem), to adequately check out a GFCI receptacle.
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Originally Posted By: jpeck
Or just push the test button.
Then check to see what is protected, what is not, and if the device itself is off when tripped, etc.
Jerry Peck
South Florida
Originally Posted By: pdacey
Good information.
I get at least one house a week where all the GFI circuits are operational when I begin the inspection, but one will not reset after being tested. The homeowners always love that.
Slainte!
Patrick Dacey
swi@satx.rr.com
TREC # 6636
www.southwestinspections.com
By the way, after resetting them, check for reverse polarity. Some of them will reset ‘reverse polarity’.
Play around with the button and you can do it to those models by pressing the reset button on one side at an angle, to reset it properly, press straight on in the center.
Those are considered "defective" and need to be replaced.
Jerry Peck
South Florida
Originally Posted By: phinsperger
Quote:
WARNING: According to a study (based on data accumulated by the American Society of Home Inspectors) published in the November/December, 1999 issue of the IAEI News, out of 1,583 GFCI circuit breakers tested, 21% had failed. Out of 4,585 GFCI receptacles tested, 19% had failed. The failures were primarily attributed to damage from short circuits and voltage surges (lightning and other transients) to the metal oxide varistors (MOV) that are used for built-in surge suppression. In areas of high lighting activity such as Southwest Florida, the failure rate for GFCI circuit breakers was over 57%!
Is the GFI failure rate really that high in Florida? ![icon_eek.gif](upload://yuxgmvDDEGIQPAyP9sRnK0D0CCY.gif) Jerry, are you finding this? It seams very alarming rate to me.
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
Some of the older ones have a high failure rate.
One brand, I forget which, could be reset to reverse polarity on almost all of them. The newer ones seem to have corrected that.
Jerry Peck
South Florida
