Today, I called an electrician about a receptacle under a sink. I was under the impression that all receptacles within 6’ of a plumbing fixture should be GFCI protected.
He stated in our area that is not a common practice under the sink to put in a GFCI receptacle because people normally don’t stick their hands under there. Also, because of it’s location it may nuisance trip.
Did you get the part about GFCI protection is only required on the receptacles servicing the counter top in the kitchen? The receptacle for the garbage disposal (under the sink), does not to be GFCI protected. Most jurisdictions have not implemented the 2014 NEC yet, so you have some time on the DW, if new construction.
Since we are not performing code enforcement inspections, whether the code has been adopted by the particular municipality is irrelevant. The “current” standard of safety, as of 2014 if you refer to the NEC as your authoritative source, is that the outlets under the sink should be GFCI protected. As such, I document them as not meeting the most current standards when they are not GFCI and AFCI protected, so that my client can make an informed decision as to how important that is to them.
Care to share why you would not want or recommend the gfi protection ? Do you you not recommend the gfi protection for countertop or other areas when it is not installed ? If so why the difference ?
Also, keep in mind that AHJ requirements for building standards may differ from licensing requirements for trades. In our area, many AHJs have not yet adopted the 2014 NEC, however the state agency that licenses electricians has adopted it for any work started after September 1, 2014. Work started after that date and performed by a Texas state licensed electrician must conform to the 2014 NEC, whether the AHJ requires it or not.
