gfci
Originally Posted By: cnounnan
Can one outlet gfci disable another in the home. Example: there are 2 gfci’s in a bathroom and one disables another or a kitchen gfci disables the exterior gfci’s.
Originally Posted By: jpope
The redundancy is not required but there is no rule that disallows it.
I usually recommend that the downstream GFCI receptacles be replaced with standard receptacles.
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Thank you very much for you quick input Jeffrey.
Originally Posted By: ckratzer
I believe a kitchen circuit is not to share with other rooms in the house.Maybe a sparkie will come to the rescue.
If my interpretation of NEC 210.52(B)(3) is correct, the general kitchen circuits can be part of the same circuit as other rooms (dining room, breakfast room, etc.), however, there are dedicated circuits required for the kitchen as well.
Jeff Pope
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: Steven Brewster
IRC E3603.2 corresponds with what Jeff posted as the NEC guidelines.
I do find that some exterior receptacles are connected to GFCI's either in baths, kitchens or garages but these homes are usually > 10 yrs. of age.
