Hello, I came across this 100 amp panel in a duplex that had the Grounding conuctor connected to both bus bars. To me it does not seem correct being that i did not find any ground wire leaving the panel to connect to a water line or a ground rod. I may be overthinking it but would like other opinions. Thanks in advance.
Now we need a photo of the upper half of the panel!!
Jeffrey nailed it more information needed. Looks like the tie bar between the two neutral buses was removed and replaced with the jumper. Need more photos to make that determination.
