Sorry to flood with questions but here’s one more:
Can anyone find the grounding electrode conductor? Shouldn’t it either come off the meter box or the main service panel? Couldn’t find any grounding rod either.
It is most likely inside the meter can.
I agree with Roy, some electricians will run the ground inside the larger PVC conduit to save material, (about $3) however you can’t assume it is. Write it up as no visible grounding electrode recommend a qualified electrician evaluate etc
Thanks Don, that’s how I wrote it. Though there probably is one in there somewhere, so didn’t want to scream this from the rooftop, but simply noted that none was visible and rec further eval. Thxs
