Hi all.
Don’t see too many but here is what looks like a grounding road at my inspection. Should there not be any wire connections? I don’t see any connected to it. Am I missing something?
Thanks for your help.
If it’s not located near the meter, it possibly is an abandoned lightning rod ground rod. Although ground rods should be buried beneath the soil line, many times you come across those that are not.
I agree with Thomas that if it’s not located near the meter or Panel, then most likely an abondon ground rod from yesteryear.
Thanks Guys.
