I thought I seen it all but this is this what a roofer does when they run out of material for downspouts?
Based on a close inspection of the gutter installation shown in the image, here are the primary issues:
Discharging Gutter Directly Above Another Gutter: The higher gutter run on the left discharges water via an end-piece drop/downspout directly into the middle of the lower gutter section running to the right. This creates unnecessary splashing, potential overflow during heavy downpours, and concentrated wear in one spot.
Improper Draining/Routing Configuration: Instead of routing the water safely away from the foundation or combining the runs correctly into a single downspout system at a corner, the upper run dumps onto a lower, shorter section that lacks a proper continuous slope or dedicated outlet away from the structure.
Improvised and Failing Joints: The transition piece connecting the short drop from the upper gutter to the lower run looks poorly fitted, messy with sealant, and prone to leaking or catching debris.
Debris Accumulation and Staining: There is visible organic debris and overflow staining along the face of the gutters, indicating that water management and flow are already compromised at these joints and corners. Any other issues?
1: The right gutter is site manufactured.
2: The downspout extension was poorly assembled, allowing liquid to escapes at joints.
3: Dirty grimy gutter pan front is due to overflow from blockage or poorly sloped gutters.
4: Missing diverter flashing along the exposed ridge shingles.
Refer to a licensed gutter installation and repair contractor for further evaluation, cleaning and repairs.
That AI statement is making things up to sound relevant, but that was not the only problem. It was terrible. Just terrible. And if you or any other inspector thinks that the AI observations above should be relied upon in any way whatsoever, you are sorely misled.
The argument for integrating AI into the home inspection workflow comes down to an undeniable industry shift: speed and operational efficiency are scaling rapidly.
Proponents point to measurable advantages that are changing how inspection businesses operate:
Drastic Reduction in Turnaround Time: Traditional report writing can eat up 2 to 4 hours per property after leaving the field. AI-assisted tools, voice dictation, and automated photo-categorization can slash that administrative burden down to a fraction of the time, allowing inspectors to deliver same-day reports or even finish them on-site.
Consistency and Professional Formatting: Software platforms leveraging smart workflows help standardize terminology, ensure grammar and formatting are pristine, and keep narrative structures uniform across hundreds of reports.
Business Scalability: By trimming hours off the back-end paperwork, inspectors reclaim the bandwidth to take on additional weekly appointments, streamline client communications, and handle CRM tasks that fuel business growth.
The core tension in the market isn’t whether technology is changing the landscape—it’s how to balance software automation with the irreplaceable expertise of a seasoned inspector. The tools that succeed are those that act as an efficient drafting assistant rather than an autonomous decision-maker, leaving the final accountability squarely where it belongs: with the professional on-site. Hope that clarifies the issue of increased technology and artificial intelligence implementing into program software. Our profession is safe for a few more years?
You’re entirely right that if the final product is crap, process doesn’t matter. Accuracy is the absolute bottom line in this business—no one is arguing otherwise. Letting the buyer know current conditions of the house they are considering buying, and making a decision what to do with that information. Guessing that what they are hiring us for last I checked.
That concise description is fantastic and hits the nail right on the head for a professional inspection report. It’s clear, direct, and focuses cleanly on the functional defects (clogging and leaking) without unnecessary optional filler.
How about the evidence we see? It definitely leaks. Almost all gutters are prone to clogging. I don’t see a real problem with the configuration other than it’s apparent leaking issues.
But AI dreamed up a whole nightmare. It is a weird machine.
In my opinion, it’s way more prone to clogging than a conventional gutter/downspout arrangement. The transfer section will not have much velocity and things will stop moving. It is leaking currently, and even if you slap some caulk on it, it will still be prone to leaking in the future because it will hold debris and water. I agree on the AI nightmare. I read that and expected a much worse picture below.
And the majority of everyday people aren’t stupid and are catching on quickly to AI. They’ll read comments like that and realize it was AI generated, and then wonder how intelligent their inspector really is without the assistance.
And of course, as already mentioned, confusion and misinterpretation by AI generated comments.
So true, and when we (fellow inspectors) criticize AI, there is a whole other group running to its defense. Why are people so defensive about an inferior machine? When it gets better, we will know it, but only if we continue to have a critical eye.
