Just inspected a house here in SW Florida and to admit my short comings, I am not the most educated on Chimneys for wood burning fireplaces. Because we run into them one time every…maybe every other year. Not to much of a need for them down here.
Upon inspecting this older home I looked up the metal prefabricated flue and saw a wind turbine. The turbine is connected to the actual flue of the chimney. I have never seen this before and am seeking further guideance. How would this be properly written up?
Safety concern: Improper type cap in use, potential for down drafts, recommend review by a qualified specialist to repair or replace as needed before closing.
It would seem to me that once that turbine got up a good head of steam, the suction would draw more heat and create more speed in the turbine, which then would draw more heat, which would then create more speed, which would draw more heat, which would…
…until the uplift in the turbine would lift the house off its foundation and send it spinning into the sky until the turbine finally broke from over-use and the house came down in Kansas.
The chimney cap must be a listed component. Suggest further evaluation by a qualified licensed chimney specialist to verify that this was a listed component for this particular chimney system.
Seems a turbine would just cause the outside opening to decrease in size and thus impede proper exit of exhaust gases in the same way a Louvered door opening impedes makeup air from entering a utility closet.
You can’t count on it spinning and exhaust depends on natural rising through convection.
The large Canadian HRV company, Venmar (now owned by Broan), grew from these in the early 1980’s but…now do not make them. (see http://www.venmar.ca/ve_basse_multi_eng.aspx ) They do not make them because they don’t work well and can allow downdrafting. Until they stopped making them about 1990-2, I believe, I fought against this concept and company until they moved to making air exchangers and HRV’s. I now consider them as producing one of the best 2 HRV’s!!!
On Sunday past, I was working in the World Heritage Site and historic fishing community of Lunenburg, NS (http://en.wikipedia.org/wiki/Lunenburg,_Nova_Scotia and drove by a house with two turbines on the roof…both were covered and sealed with plastic bags and duct tape!!
These turbines are in my “Smoke and Mirrors” list of popular energy misconceptions. In the mid-late 1980’s, Canada Housing and Mortgage Corp. sponsored testing by an engineering firm to determine the effectiveness of increasing ventilation versus other methods. Turned out that they were slightly better (8% or so) than the "chicken coup ventilator"consisting of a vertical pipe/duct with a conical rain cap (think of the Tin Man).
The main mover of air in both of these units is (1) wind moving over the top, creating a draw like wind over the top of a chimney flue and (2) if there is warm air in the attic from air exfiltration through ceilings, etc or from solar heating of the attic, the chimney or stack effect is working (warm air rises).
The turning turbine creates the mind illusion of a fan which we know moves air… but the fan is driven by high grade electricity converted to mechanical energy. The wind driving force for the turbine is not converted to another energy type nor is it stepped up or down in quality nor is its ability to do work multiplied as it is in our simple tools such as a lever, screw or pulley. Thus the turbine ventilator “appears” to create “work” and is “Smoke and Mirrors” or an illusion.
