I guess it depends if we are venting individual stud bays (vaulted ceiling) or an open attic.
Doesn’t look like much room for either!
I’ve been pondering this myself. I can’t recall ever seeing a vent setup installed like that. Similar to it lower on a roof by a few shingle rows but not at a head wall like that. Is it an attic vent or does it serve another purpose? Are there soffit vents in that immediate area also?
I understand that they do things totally differently there than they do here but 99% of builders here wouldn’t add venting to such a small area like that.
I’ve seen small porch roofs, small garage roofs, and small bump out roofs with and without this type of vent. Mostly no vent nowadays. I don’t really see much of a problem with it and I don’t think it really does much.
So, the contractors have been working and removed most of the wall coverings. The leak from the headwall flashing that took part of the ceiling down is actually the least of all that’s going on. TONS of termite and wood beetle damage. This storm is almost a blessing since this wall really needed to be opened up.
It’s a gable end so not much load bearing other than the dark wood beams and framing holding them up. Some of that is trashed and I don’t know how it’s even still standing. To a large extent, this is just the normal life cycle of a building in Hawaii. This place was built in 1972 and it was just time to get in the wall and do some replacements. It’s hard to tell with the light coming in the windows but the left side was redone about 8 years ago. The right side is where all the damage is currently.
Does Robert always respond as if he’s a large language model, i.e. A.I.?
Does Robert always respond as if he’s a large language model, i.e. A.I.?.
I’ve noticed that there are some on this forum that do that.
People may think by using AI like that it makes them sound smarter.
It is kind of funny to read it…and, a little cringey, too.
But I don’t think they notice. shrug
I think it has been pointed out a couple of times before.
Really? Even his responses to responses are like…a bit odd. And I’ve been on here for years and it always seems that way.
I mean I don’t use it, but I understand it can be useful. But at least put it in your own voice? I don’t know.
It has also been rumored that he likes to cut & paste as well. I don’t know if it’s true. Just what I have read.
It’s absolutely true!
Next time he makes one of his weird posts, (shouldn’t take very long), Copy it to Google, and more often than not it will come back with an exact match (sometimes a near exact match). Rarely will it not return a match that gets him off the hook. I’m sure you’ve seen my posts that call him out on his thievery, and scold him for not disclosing his ‘sources’. The use of the above method is exactly how I “busted” him for it!!
Note: Now that he is figuring out AI, and he finally ‘closed shop’, he has too much time on his hands, so his responses have become multitudes worse.
oo obvious to be the problem, but….what is going on here?
It’s proper to leave a drainage path, the roofing should not be cut tight into the step flashing.
With that small section of roof I would eliminate the vent under the window
Yeah, I agree… it was a nice idea by the roofer but with the ocean and wind exposure I think it’s best to omit it.
Agreed. Perhaps it is a resolution issue on my device, but the gap appeared to have a hole.
