Height of fence around back yard with pool.
Originally Posted By: jpope
rgippner wrote:
Did you notice that the barrier illustrated on the first page would not be approved as the links are big enough to use as ladder rungs to climb over?
Pool barriers must not be climbable.
rgippner wrote:
Out here in California if your lot is big enough you don't need a fence.
I would like to know where you got this misinformation. New construction does not allow the installation of pools without proper barriers regardless of the size of your property (per UBC). This applies to all pools and spas >24" deep.
In the case of the above ground pool, the pool wall acts as the barrier and there is no additional requirement if the wall is 48" high. The ladder or steps, however, must be lockable or have a barrier.
Jeff Pope
JPI Home Inspection Service
"At JPI, we'll help you look better"
(661) 212-0738
