SAFETY CONCERN: Excessive variation in tread width…
Ummmmm I see a door sill and two stair treads.
What problem do you see?
Cheers
First tread is 3" wide. From door sill to first full tread is about 12"
Every landing shall have a minimum dimension of 36 inches measured in the direction of travel. Exterior landings shall be permitted to have a slope not to exceed ¼ unit vertical in 12 units horizontal (2-percent). R311.3.1 Floor elevations at required egress doors.Jan 30, 2017
Safety Recommendation: Trip hazard. Does not conform to recognized building standards. Blah…blah… blah
^^^^^yep^^^^^
No landing,
Inconsistent riser height,
inconsistent tread depth,
possibly treads not level,
maybe more…
^^Thats the key word to get correct^^
Width looks just fine to me!!
Thanks
I think I’d be more concerned with that DIY caulking mess and/or the probable lack of flashings at the concrete/house substructure abutment. Did you measure the moisture content at this area when inside?
