High Loop on Side of New Dishwasher
(Paul Cummins, 333800000604) #1
I just installed a new dishwasher and it wrapped the discharge tube high on the left side of the machine. Does this mean new ones don’t need a high loop in the cabinet? Is there a year this was required for new dishwashers?
(Joshua L. Frederick) #2
Still needs high loop
(Roy Lewis, CMI - North Florida Inspector) #3
Read the manufacturer’s information…
No ! Not always do you need the high loop as you call it.
However, a high drain will alway work.
(Joshua L. Frederick) #4
(Linas Dapkus, CMI) #5
No wonder he failed as a contractor.
(Bob Elliott, 450.0002662) #6
Is that less than a failed Union Laborer ?
(Linas Dapkus, CMI) #7
That’s a retired Union Laborer with retirement pay than is more than a failing, inept home inspector:
http://www.nachi.org/forum/f2/mansar…estion-100520/
http://www.nachi.org/forum/f2/water-…athing-100014/
http://www.nachi.org/forum/f2/floor-…uestion-96658/
http://www.nachi.org/forum/f77/flat-…lashing-96464/
http://www.nachi.org/forum/f2/yes-as…on-here-94618/
http://www.nachi.org/forum/f79/hardi-board-94457/
http://www.nachi.org/forum/f2/asbestos-93464/
http://www.nachi.org/forum/f2/correc…commend-93036/
http://www.nachi.org/forum/f79/plastic-pipe-id-92769/
http://www.nachi.org/forum/f2/gas-re…r-issue-92316/
http://www.nachi.org/forum/f2/deck-l…bracket-91730/
http://www.nachi.org/forum/f2/power-…uestion-91670/
http://www.nachi.org/forum/f2/need-h…ding-id-91281/
http://www.nachi.org/forum/f2/wood-shingles-91255/
http://www.nachi.org/forum/f2/open-grout-stone-90912/
http://www.nachi.org/forum/f23/ridge…oration-90139/
http://www.nachi.org/forum/f2/foundation-puzzle-89879/
http://www.nachi.org/forum/f77/shoul…lashing-89354/
http://www.nachi.org/forum/f2/type-brick-89500/
http://www.nachi.org/forum/f2/roof-t…-issues-89312/
http://www.nachi.org/forum/f2/400-am…service-89159/
http://www.nachi.org/forum/f2/air-dr…air-gap-88205/
http://www.nachi.org/forum/f22/plumb…uestion-88052/
http://www.nachi.org/forum/f77/coati…uestion-85912/
http://www.nachi.org/forum/f2/post-called-again-85944/
http://www.nachi.org/forum/f16/lot-d…uestion-85643/
http://www.nachi.org/forum/f2/exteri…-needed-85642/
http://www.nachi.org/forum/f2/component-85394/
http://www.nachi.org/forum/f2/unusual-foundation-85254/
http://www.nachi.org/forum/f2/foam-w…heeater-84487/
http://www.nachi.org/forum/f2/roof-deck-ok-82934/
(Bob Elliott, 450.0002662) #8
I do not think you inept so much as psycho but try not to beat on yourself too hard as you might sprain something…
(Russel Ray) #9
I’m confused.
Out here high loops have never been required per sé, only when there’s no vent cap. In 11,800+ inspections since October 2001, I can count on one hand the number of high loops I have seen.
(Roy Lewis, CMI - North Florida Inspector) #10
Eat me you F**King prick!
I hope you die in a horrible accident today … And suffer till you die. Really!
Don’t f**k with me anymore…Get it?
(Linas Dapkus, CMI) #11
Did I say something wrong??
I wasn’t even referring to you. You must have some sort of guilt complex.
Get professional help Robert or Roy.
(Roy Lewis, CMI - North Florida Inspector) #12
Yes you were . You have used that line at me many times…
(Linas Dapkus, CMI) #13
Sorry, but you have me mistaken for someone else.
(Roy Lewis, CMI - North Florida Inspector) #14
I’m done with you…again!
I still hope you die in a horrible accident today … And suffer till you die.
(Joshua L. Frederick) #15
I say that about weep holes/screeds in masonry siding, kick-out flashings, distribution panels properly wired, properly grounded 3-prong outlets in an older house,
etc. etc. etc. as well.
It is what it is.
(Paul Cummins, 333800000604) #16
Sorry to have started an unpleasant discussion but, if we can stick to the facts, it seems to me that if the discharge tube is looped on the dishwasher itself and then attached directly to the disposer, then the disposer cannot back-flow into the dishwasher. If you have responses please state your rationale for them, otherwise they’re not much help. There is no way to check the side of each dishwasher so I was wondering if we need a new rule for the new ones. Thanks, Paul
(Roy Lewis, CMI - North Florida Inspector) #17
From Maytag…
(Russel Ray) #18
I only say it about dirt legs on gas lines and high loops. All the other stuff you mentioned are things that we do regularly here in San Diego, but gas lines and high loops are very rare. We prefer standard air gaps instead of high loops.
(Joshua L. Frederick) #19
Did you read the link I provided?
(Linas Dapkus, CMI) #20
If you feel that way Robert, I think I’ll stay in bed today.
Do you think it will be safe for me get get up and about tomorrow?
