How about opening the garage door when the remote starter is activated?? Well, I guess the remote starter would not know if it is outside or inside the garage, would it?? Answered my own question I guess. ha. ha.
Marcel
</IMG></IMG></IMG>
Marcel
</IMG></IMG></IMG>
Does not have to be metal clad - read the codes. Can be solid core wood if thick enough. If the door is paneled - the groves in the panel may be less than the required depth even if the rest of the door is thick enough.
Like several have said - the IRC does not require the self closing part while UBC does.
**[size=3]Rated Doors
http://www.trustile.com/catalog/firedoors/?series=0
**[FONT=Century Gothic](NON RATED) **
[/FONT]& (20 MINUTE RATED)
**Neutral Pressure
MAXIMUM SIZE: LITE OPENINGS:
**Non Rate **
Cut-out area may not exceed 40% of the face or exceed
4-0 x 10-0
half of the door height to comply with warranty.
Cut-outs must be a minimum of 5" from the edge of the
8-0 x 10-0
door, or any other cutout (lite or hardware ).
**20 Minute Rate
**Total visible area of single or multiple lites may not
4-0 x 10-0
exceed 1296sq. In. per leaf. Maximum width of any lite
4-0 x 10-0
can not exceed 36" and the height can not exceed 54".
Louvers are not allowed on 20 minute rated doors.
8-0 x 10-0
**Note: WARRANTY:
a)
Option: Fire Rated meeting edges may be One year, interior use only. See warranty terms and
conditions. Use of Masonite doors in exterior applications
is not recommended and not warranted
**DOOR THICKNESS:
1-3/8" (Non Rated) and 1-3/4
**STILES
Minimum
7/8" Softwood. Mill option F/J
stiles with paint grade faces.
Option: Matching (compatible) hardwood stiles.
**RAILS:
Minimum 1-1/8" mill option rails
Option: Matching (compatible) hardwood rails
**USES AND APPLICATIONS:
Residential
doors recommended for high traffic areas.
This construction allows for many types of hardware
and lite/louver applications.
**FLOATING CORE/FRAME ASSEMBLY
May be any combination of blocks or strips, not more
than 2-1/2" wide, of one species of wood at 6% to 9%
moisture content. Joints tight and staggered in
adjacent rows.
**LABEL SERVICE:
Intertek Testing Services - Warnock Hersey International
( ITS-WHI )
**FACES TO SPECIFY:
T
hree or 4-ply door skins
Wide range of veneer species in various cuts.
Medium density overlay and hardboard.
ADHESIVES:
Core/Frame Assembly
used for 20 minute pairs in lieu of metal edges.
Single doors…………………….…………….
Maximum Size Door/Transom unit…
Regular & Double Egress
paired doors……………………….………….
Marcel
[/size]
