How can you visually identify TAP Insulation?
Is there a way to visually identify (TAP) Thermal, Acoustical, and Pest Control insulation? I see images of it online but it looks like standard loose-fill cellulose.
Jay, I sent an email to the manufacturer and here is their response:
Larry,
**There is not a way to distinguish “exactly” our product out in the field. We train our clients to fill out and leave the TAP Attic Fact Sheet or our TAP Warranty Card, in the attic stapled onto a joist near the entrance as a way to identify the TAP, however that unfortunately doesn’t always happen. **
Stephens Brown
Director of Sales & Client Support
C:770-561-3090
Pest Control Insulation, LLC
Helps keep bugs out - and comfort in!
Thanks Larry!
Go to their website. They used to pass out free samples if you ask nice!
I got one a few years ago (ziplock baggie size) and yup, couldn’t see any difference at all holding it in my hands. Good luck in a dark attic! :wink:
https://tapinsulation.com/product/tap-insulation-sample/
There is no visible difference. Standard Cellulose uses Borate as the fire retardant and Cellulose that is sold as Pest/Rodent control will just have More Borate added. “TAP” is new only that this particular manufacturer is labeling theirs with the copyright TAP. Back in the 80s and nineties we used a couple of different brands of cellulose with this increased amount of Borate added. One Brand was called something like “Inscide” (I believe it was manufactured by Applegate). All of it looked the same*. Cellulose has changed visibly over the years mainly because 30-40 years ago it was almost exclusively made from newsprint (Newspapers), as newspapers have went the way of the corded phone, you will see much more cardboard and slick paper (magazine) being used…
  • We did do a few homes back in the late 80s or 90s for people that were chemically sensitive with Virgin Newsprint and Only Borate (Boric acid) as an additive. This was newsprint that the manufacturer made especially for us from the very end of the rolls left over after after the daily paper went out. It was white, pure unprinted paper. It was a joy to spray in walls. (what we called Wet-Spray). it took much less water to spray and was very clean with very little dust when blown in the attic dry.
Do you have any photos of the questionable insulation?
TAP insulation is distinguishable from other insulation, take a UV flashlight into the attic with you next time and check
It out… UV light, not a black light
what wavelength? all black lights are uv lights, just a certain wavelength. around 400 from what i recall. what wavelength reveals the difference?
Above link no longer works…
Contact them at: Contact Us — TAP® Pest Control Insulation - TAP® Pest Control Insulation
Videos at: https://www.youtube.com/channel/UCoTvnHt3_ImsZgE-ZZs7Kkw
