How to collect a Vermiculite sample?
[quote= Because you never seen it does not mean it does not exist.
BTW Roy has forgotten more then you will ever know.[/quote]
Thanks Vern I do try to help all .
Too bad some one else does not try and help instead of making so many usless posts .
I’ll give him that in commercial/industrial wiring that I never worked in!
I see you edited/posted this little comment, after I replied to your good friend, Vern., explaining that his references may be wrong since they talk about “asbestos-cement siding shingles” or is he wrong in his understanding of the product?
If my presence here is so bad, I can be kicked off the boards as some have been and currently are banned from here and other boards. I have had INACHI members contact me in the past week and a half to discuss “issues”…why me??
I’ll mudify the discussion even more.
In the late 1950’s and 1960’s I worked for my Dad, a building contractor. I helped to install thousands of ‘asbestos shingles’ on walls. The siding panels were referred to as shingles.
I just found a 1935 ad from Johns-Manville (a manufacturer) raving about this revolutionary product that will ‘make your home like new’. They clearly advertise a siding product that they call “Johns-Manville Asbestos Cedar siding shingles”.
Merry Christmas
Bill Mullen
To bad Brian you just Confirmed again exactly what I was posting about .
(" Too bad some one else does not try and help instead of making so many useless posts . ")
You have lots of knowledge and sharing it helps all .
To continue on belittling others does not help our industry.
I think your friend, VERN, began the little peeing match by trying to gain some recognition points with a post that was a bit off topic and essentially saying I was wrong by saying the siding was not called “shingles” (which, BTW, his own references proved differently). SAD!!!
If you don’t think information was not added to the boards here, then go to ACHI school. Isn’t it interesting that this company ( http://www.lcsairtest.com/ ) is asking me for more info?
And you continue to prove you do not have the ability to just walk away or ignore.
A discussion ? disagreement ? and you seem to start most all by your self .
You see a post and frequently jump in with a confrontation attitude .
It’s amazing how the mchash knows what was used on the walls of a house he has never seen. I live one block away from that house and it had asbestos siding. If he would look at the drawing he would see that siding is different sizes then the shingles. Since he knows what was used three thousand plus miles away I wonder if he uses the same methods when he does inspections. some call it drive by or soft and the re’s love it.
So, Vern, you did see it, and know which style is on the house and where…who cares? To myself. the important issue is that an asbestos-cement product was on the outside of this house and the government had the house closed in to take off a non-friable asbestos product. IMHO, it’s overkill for the risk is definitely very, very low as opposed to friable spray-on asbestos containing insulation being removed inside a school.
As mentioned before, would an insulation contractor have to enclose the house to install insulation from the exterior by siding remopval/replacement?
BTW, which style of asbestos-cement siding was on the house, clapboard or corregated? And would you agree with the documents on asbestos-cement exterior finishes, the smaller roughly 1’ by 2’ siding product is called a “shingle” in the industry.
*** Who cares what they call it*** . If it could contain asbestos I will tell it like I see it
This is from 2007 ,I expect insurance companies have not made it easier to get insurance .
I will tell all my clients (" suspect this siding could contain asbestos ") and some insurance companies could have some concerns .
[FONT=Verdana-Bold][size=5][FONT=Verdana-Bold][size=5][size=2]http://www.opic.state.tx.us/docs/438_2007_home_underwiting.pdf[/size][/size]
2007 Homeowners Insurance Underwriting Guidelines
[/FONT][FONT=Verdana-Bold][size=1]Produced by the Office of Public Insurance Counsel
[/size][/FONT][FONT=Verdana-Bold]UNDERWRITING GUI[/FONT]
[FONT=Verdana-Bold][size=2]SIDING[/size][/FONT]
[FONT=Verdana][size=1]Some companies make adverse underwriting decisions based on the make up or
condition of the siding of a home. The types of siding include, but are not limited to:
Exterior Insulation and Finishing System (or E.I.F.S - a synthetic stucco), asbestos
materials, or roll type siding.
32% 11% 33%
[/size][/FONT]
[/size][/FONT]
Have you been exposed to asbestos? Do you think it’s not harmful?
Vern, you have not answered a couple of my questions and have tried to change the topic of our last few posts…OK!
Yes, in the past, I have removed and re-installed 1,000’s of asbestos-containing siding shingles for the purpose of installing blown insulation.
Yes, I think it’s harmful in very high daily doses over years and years…as that has been the history of the diseases.
No where did I say workers removing asbestos shingles should not wear protective masks and coveralls, not use water and vacuums to control/capture the few asbestos fibers that may be released in careful asbestos shingle/siding removal.
Do you live and work in Edmonton? If so and you are afraid of asbestos exposure, I would wear a proper mask at all times!! As Stephen Reut has said and I calculated, even out fishing, you may inhale to up to 365,000 asbestos fibers per year.
Please answer my few simple questions!
Stepan,
My name is Beauchemin, Marc-Andre. When I come across vermiculite, and I often do, I red flag it verbally to all, and I write it into my report. I tell my client that it may or may not contain asbestos, I explain that independent and professionnal companies are equipped to take samples and analyse those samples in labs. Samples aren’t 100%. I then explain that electricians,cable guys, phone guys, plumbers and roofers to name a few sacrifice themselves and go through attics all the time. I finish by saying that an attic is not a campground.
BMAinspection.com
The risk/liability to the home inspector is if you take the sample incorrectly you may contaminate the entire home with asbestos. Also, if vermiculite samples aren’t taken in the correct places of the insulation it may not return correct results. I suppose it is no different that the risk involved with wrongly inspecting anything, but here in Nova Scotia asbestos is a “bad word”, and insurance companies want to stand clear. I was an asbestos abatement contractor for a few years, I’m trained and certified, and won’t go near sampling with a 10 foot pole. Waaay too much liability.
You lost me on that one, can you clarify that for the interest of all? How can you contaminate the entire home? Do you mean falling through the ceiling and releasing potential asbestos fibres?
Thanks,
To take a vermiculite sample in an attic properly you must take samples at different locations, at different depths. Therefore, you need a tyvek suit, boot covers, latex gloves, and a respirator with P100 filters to protect yourself while crawling around in the attic. Upon exiting the attic, you should be stepping down into a small enclosure made from 6 mil poly or better, which will allow any of the insulation that falls on the floor to be collected and cleaned up inside the enclosure. To clean it up properly, you need a HEPA vac, a surfactant to lock down any potential fibres left in the area, and proper labelled asbestos disposal bags. If it is suspected to be asbestos containing material, then it should be treated as such. The only way to properly collect a sample IMO is to build an enclosure at the base of the hatch to avoid releasing fibres in the air, or tracking them through the home possibly contaminating the dwelling. Anyone thats been in an attic knows its almost impossible to exit an attic and not get some insulation on the floor below, thats where the problem can be if its ACM. IMO, if you don’t know how to do it right, you shouldn’t be doing it at all…and thats the problem, most do not know how to do it right.
This is just one of many Law suits re Asbestous . PLease do not miss reporting it.
Asbestos Lawsuits - Just What You Really Ought To Apprehend Relating to Asbestos Lawsuits
Dec 25th, 2010 by VarekaiTreyach | 0
As a result of lengthy latency amount of asbestos lawsuits-related conditions, signs commence to appear a few 15 to four decades following the person’s experience of asbestos lawsuits. It really is lucky that the nutrient is no longer trusted within the present-day, yet those who had been subjected to the factors years in the past maybe suffering the outcomes now or perhaps the coming years.
The causes of lung cancer fluctuate. Aside from contact with asbestos lawsuits, smoking cigarettes as well as air pollution can easily result in the oncoming of the condition. As a result, avoiding these kinds of feasible cancer-causing real estate agents is essential with regard to healthful bronchi.
Thus, the building business appreciated asbestos lawsuits. For a while, it had been included with vinyl floor coverings, insulation, roof tiles, roof tiles, as well as roof covering black, amongst a great many other points. Consequently, maybe it’s present almost all surrounding you. If you think that there are asbestos lawsuits in your home, you should contact a professional asbestos lawsuits inspector. Do not make an effort to analyze the compound your self, since you may reveal you to ultimately the actual carcinogen.
Should you or somebody continues to be identified as having mesothelioma, you need to talk to any lawyer concerning the legitimate choices on hand. To find out more, browse the mesothelioma attorneys at the organization regarding Williams Kherkher nowadays.
Home renovation is probably the most favored weekend past occasions today, along with increasing numbers of people influenced to boost their particular homes and most performing the actual tasks by themselves. Nonetheless, if you are planning to begin virtually any home Do-it-yourself jobs, after that you need to know a little about asbestos lawsuits and some of the asbestos lawsuits risks, to keep your household risk-free.
asbestos lawsuitsis may be the expression used for the medical problem you can acquire any time breathing in asbestos lawsuits materials. Additional conditions that could take place due to heavy experience of asbestos lawsuits fibers are mesothelioma and getting the lung cancer. Due to wellbeing effects of asbestos lawsuits, an as well as usage of asbestos lawsuits products are already prohibited in Australia within 1991 however ordinance on asbestos lawsuits elimination and also government didn’t begin right up until august 2005.
When American doctors began reporting on asbestos lawsuits-related conditions starting noisy . 20th century, many other nations around the world started out realizing the particular associated health issues too. asbestos lawsuits brings about things like asbestos lawsuitsis, pleural plaques, pleural thickening, lung cancer, and also mesothelioma, amongst others. Thankfully, asbestos lawsuits has become prohibited in the united states, nonetheless it came too far gone for many individuals.
When you have the home that was constructed prior to the 70s, you ought to uncovered at heart, in which prior to wanting to do any home refurbishments, this is an excellent idea to offer the home inspected with regard to technique asbestos lawsuits material.
Shipbuilding was one of the major industries in which included handling asbestos lawsuits. With this area, asbestos lawsuits had been widely used regarding helping yachts as well as freighters in order to insulate central heating boiler, warm water plumbing not to mention heavy steam plumbing. Because this material was simple to receive, process and also to transfer, this particular mineral was heralded because wonder nutrient right up until everyone was not aware to the fact that it may cause a wide range of health disorders however. Slowly, some automotive sectors also started out using these components regarding manufacturing clutches tires along with other car elements. Total, asbestos lawsuits identified it’s way into vermiculite backyard materials, ground floor tiles and also threshold, sewage components, drinking water supply, commercial and household creating components.
In case your home is discovered to be able to consist of asbestos lawsuits, it is best to get in touch with the asbestos lawsuits Removing Installers Connection or even have a look at the local Phone book cell phone directory for additional entries around the proper those who ought to take care of asbestos lawsuits elimination.
This writer own an authority websites about atlanta asbestos lawsuits, asbestos settlement amounts & atlanta asbestos lawsuits. Check out his site to know a lot more about asbestos lawsuits in general.
And another
http://alltrands.com/asbestos-lawsuits-just-what-you-would-need-to-aware-of-when-it-comes-to-asbestos-lawsuits.htm/39804
And another . Be smart stay out of Court
Asbestos Lawsuits – Unquestionably The Supreme Article Concerning Asbestos Lawsuits
24.12.2010 | Author: VarekaiTreyach | Posted in Disease & Illness/Mesothelioma
At the beginning of the 20th century, equally U . s . and also Uk medical doctors observed the rise in illnesses in which corresponded using the increased using asbestos lawsuits. In 1906, an English physician reported the initial case associated with asbestos lawsuitsis. By the 1920s, many individuals recognized that jobs for example asbestos lawsuits exploration led to condition. This caused the us government in order to conduct a study around the safety of asbestos lawsuits inside the 1930s.
First, you must realize that asbestos lawsuits can have a number of helpful attributes that added into it learning to be an extremely popular component. This is a member of the particular silicate family. Silicate loved ones components are usually lauded for their insulating qualities, as well as asbestos lawsuits is no different. It really is resistant against heat, fire, chemicals, electrical energy, and also wreckage. In addition, asbestos lawsuits provides a number of useful attributes of its personal. Including large tensile durability and also versatility.
When the perils associated with asbestos lawsuits were recognized hundreds of thousands of people that acquired previously used asbestos lawsuits jobs stumbled on the particular forefront of the court docket to be paid out. Numerous asbestos lawsuits businesses brand new the particular risks of asbestos lawsuits as well as concealed healthcare facts through employees. Consequently mesothelioma claims flooded the actual courtrooms and also bankrupted a lot of construction, roughing, and mining companies.
Regrettably, it absolutely was not necessarily before the late nineteen fifties which doctors discovered the immediate link between asbestos lawsuits and also mesothelioma, any dangerous cancer that attacks the different linings from the body-lung, center, belly, as well as testicles. Additionally, studies have additionally supplied links regarding asbestos lawsuits exposure as well as lung, throat, esophageal, intestinal, digestive tract, and also renal system cancers. Thus, by the time asbestos lawsuits was banned in the nineteen-eighties, many individuals acquired currently been exposed to this kind of carcinogen.
Today, most brand new structures do not consist of asbestos lawsuits. Nonetheless, for those who are curious about conserving historic buildings, you also have to take into account the dangers posed by this fabric. asbestos lawsuits just isn’t harmful right up until that gets airborne. As soon as this becomes airborne, individuals may take a breath and also eat this fabric. Your body can’t break up asbestos lawsuits, so the fibres can be permanently set within your tissues.
With all the broad usage of asbestos lawsuits, almost everyone may be exposed to the negative effects. Typically the most popular that will be cancer from the lung. Like every other form of cancers, the sources of this kind can affect the balance about cell development in the particular lung area — resulting to a great unchecked division and also proliferation of cells. Eventually, this can type a mass known as tumors.
Whether you were subjected to asbestos lawsuits inside a historical creating or even inside a more recent framework, it is possible to create the actual dangerous cancer associated with mesothelioma. Should you or even a friend or acquaintance offers mesothelioma after asbestos lawsuits exposure, you ought to consult with a great asbestos lawsuits attorney regarding your choices.
If you notice a place of one’s home that may contain asbestos lawsuits offers any kind of type of harm which may release fibers, you’ll want the region examined simply by an expert. Get in touch with a specialist asbestos lawsuits inspector to adopt a sample, and also take safety safety measures ahead of the sample is actually taken to be certain that you’re not subjected to fibres in the test region.
Executive and also custodial staff confront many dangers at work yet many of these tend to be visible and also somewhat obvious. Physical, electrical as well as chemical dangers are typical consistently addressed as well as given regular upkeep schedules. asbestos lawsuits, nonetheless, is the ‘silent killer’ and is often present with no warning or even peoples’ knowledge of their presence. The signs of asbestos lawsuits publicity are not quick and may take actually years to be able to materialize yet, as soon as current, they may be lethal. This is exactly why.
Appropriate asbestos lawsuits attention training may be the duty of every enterprise that properties staff. It does not take long to make people conscious of the potential risks and wise safety measures in this field. A great ounces of reduction remains well worth a pound of remedy.
To find a good deal more very good info all about atlanta asbestos lawsuits and asbestos settlement amounts, pay a visit to this popular site right away at asbestos jobs available.
http://freearticlesubmissionsite.com/wp-content/plugins/wp-spamfree/img/wpsf-img.php
Related posts:
  1. What Exactly Is Asbestos Attorney Cancer Lawyer Mesothelioma Settlement
  2. information technology schools – Roofing Denver – Is a Mesothelioma or Asbestos Case a Wrongful Death Action?
  3. Mesothelioma advise and actions
  4. orthodontics – Advice For Asbestos Assistive Article – Agel
  5. Learn Most Common Side Effects Of Mesothelioma
Comments are closed
http://freearticlesubmissionsite.com/asbestos-lawsuits-unquestionably-the-supreme-article-concerning-asbestos-lawsuits/
Related posts:
Comments are closed
