How to Inspect Private Drinking Water Wells
Cisterns are water storage tank for either potable or non potable use.
The tank can be berried below ground, or above ground.
There materials range from concrete, cement block, and fiberglass.
A non-potable cistern can be hooked up to your roof gutters and down spout to collect the rain runoff and be used to watering gardens or washing vehicles.
Potable cisterns, can also be connected to the gutters and downspout. However special consideration and appropriate measures must be taken to avoid contamination of the water.
Potable water is often delivered into the cistern/holding tank.
This is a submersible pump. It looks like it has been in use for quite some time. the red color indicates that the water well could have some iron deposits in it along with mud which could be a sign of a cave in.
The pressure tank is essential in a household to maintain a consistant water pressure. Most tanks have a 40/60 switch, but some have a 30/50 or even a 20/40 switch. The switch tells the pump when to turn on and off.
There is no such thing as naturally pure water. In nature, all water contains some impurities. As water flows in streams, sits in lakes, and filters through layers of soil and rock in the ground, it dissolves or absorbs the substances that it touches.
In rural areas, people are more likely to drink ground water that was pumped from a well. These wells tap into aquifers, the natural reservoirs under the earths surface, that may be only a few miles wide, or may span the borders of many states. As with surface water, it is important to remember that activities many miles away from you may affect the quality of ground water.
I read the article explaining why I should email Internachi before calling them. I may be put on hold if I call. Internachi may have to go to the website to look for information. I might need a document. With email, I can say exactly what I want to say.
This is a picture of the well casing and cap. You will notice that it is approximately 15" above grade level. It is located about eight feet from the side of the house,and located near the septic or anything hazardous.
Here is a well cap for a typical private well water drinking system. It seems to have fresh soil placed around it to ensure no contaminants make it inside of the closed well system. It’s also made of ABS plastic material.
Well caps should be placed far away from contaminants that could possibly contaminate the well. This would be an expensive process to fix and could potentially leave me liable for a lawsuit and ruin my company for life. That would be bad.
The picture i choose is a very basic example of the construction of a well system. I learned a lot about the construction and requirements each type of well must meet in order to pass the national standard of wells.
I article i choose is about the different type of wells that are out in the field. The first type is a drilled well, a drilled well is the most reliable. The second well is a driven well, they are the second most reliable. The last type of well is a Dug well, these are no longer allowed in residential and must be replaced and updated with a new well.
A Private well system in good condition will show no signs of leaking or corrosion and will maintain a steady pressure in the pressure tank. The pressure tank should not show signs of rust. The water should be tested at a minimum for bacteria. Well water tests can also test for lead, nitrates and other chemicals.
In the attached photo you will see an example of a dug well that is frequently found in the area that I live. These are not the only type found. In older homes you must ask the home owner and also be very aware if there is a dug well in the crawlspace. Some wells were dug, cased, and then the house was constructed over the well.
Inspecting private drinking water wells assume liability so special attention to detail is very important. Always document and photograph everything you do to decrease this liability. Several intermittent photos at different angles can help you if a problem arises with your client.
Drilled well head, located about 20 feet north of main house and approx. 100 feet from drain field. Wiring conduit has been damaged and needs repair. Well head is just over one foot above the ground. Well services 3 BR house and 2 BR apartment that are in same building.
The article I researched/read was on sump pumps.The most common deficiency is the bottom of the sump is covered in dirt, pebbles and other debris. The pumps have a screen, but this debris should be periodically cleaned out of the sump to ensure long life for the pump. If the screen fails, or is damaged, if the sump is kept clean it is less likely to have a failure.
Well casing has two open holes on side of casing a few inches above ground with rope going through possibly suspending well pump from bottom of well this could possible cause a number of health hazards recommend sealing and testing water.
Hard water issues can be costly if not maintained with proper equipment, maintaining hard water issues can cost a home owner a great deal of plumbing expenses just as supply piping appliance repair and or replacements and just a total piece of mind.
Here is a picture of a 5 stage reverse osmosis system. These systems are excellent for removing harmful contaminants in the well water. The system here is installed for drinking water at the kitchen sink and cooking. It’s also installed for the ice maker for the refrigerator. Filter replacement is fairly easy on these units, filters should be replaced every 6-12 months.
