Well inlet and PVC
Originally Posted By: abishop
http://www.nachi.org/bbsystem/usrimages/D/Dejonges_Inspection_063.jpg ]
Andy Bishop
Bishop Home Inspections, LLC
Allegan, Michigan
bishophomeinspection@charter.net
269-686-6485
Originally Posted By: bkelly2
It should be CPVC for drinking water. What pressure is the pump running at and what is the pressure rating of the pipng?
“I used to be disgusted, Now I try to Be amused”-Elvis Costello
Originally Posted By: rmoore
Gotta disagree with Brian a bit…
PVC (minimum 160 PSI rating) is allowed by the IRC (and UPC) for water service pipe as long as it terminates within 5 feet of entering a building. It's not allowed for the distribution piping. I don't do a lot of homes with wells, but I believe that would still be considered the service pipe and it looks like Andy's photo conforms.
As usual, local AHJs may differ.
Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Fair enough Richard, to me it looks like the pressure tank is in a building and any thing downtream of the tank I considered distribution piping.
Originally Posted By: ckratzer
I don’t think that’s a pump.It looks more like a pressure tank.
And that 12/2 wire needs to be in conduit.
Respectfully
Cheremie
Ok pressure tank, and you are correct, the romex should be in conduit…
Originally Posted By: rcooke
abishop wrote:
I did an inspection today and at the wall where the well water comes in, it had some PVC connections. Is this OK?
I hope i did the pic correct. It was my first upload.
[ Image: http://www.nachi.org/bbsystem/usrimages/D/Dejonges_Inspection_063.jpg ]
Andy Bishop
Allegan, Michigan
269-686-6485
I would also write up the Galvanized steel pipe that the copper pipe runs into .
It has passed its life expectancy.
Roy Cooke Sr.
http://Royshomeinspection.com
Originally Posted By: psabados
I agree with Cheremie on the tank and wiring. What would be more helpful is additional pictures showing more of the system. That pressure guage looks like its in very poor condition also, wouldn’t bet the farm on reliabilty.
Paul
NACHI Vice President
NACHI Foundation, President
Convention Coordinator
Cheremie & Paul, how can you tell the wire gauge?
Thanks for all the info!!!
Andy Bishop
Bishop Home Inspection, LLC.
269-686-6485
Brian,
Actually I can’t tell from the photo because I can’t see the wire type embossed on it’s sheathing.I just know it should be 12/2.There is a possibility that it’s 14/2 but it looks like an old installation and a good deal of “old timers” would scoff at 14/2.I personally don’t even like to put it in my new homes.I’m not saying there is anything wrong with it.It’s just my preference.
Nowadays in new construction the two types are more easily identified just by sight because the sheathing on each has it’s own identifying color.One is yellow the other being white.In addition the 12 should be on a 20 amp breaker and the 14 on a 15 amp breaker.Which you probably know.I have,though,seen many cases where the wire size didn’t match it’s breaker.A no-no if the 14 guage is connected to a 20 amp.
Nice conversing with you.Have a good day!
Cheremie
Excellent
