Originally Posted By: rcooke This post was automatically imported from our archived forum.
The reason they have done this is too make sure only ONE piece of equipment operates at one time .
They might not have spare breakers or a large enough service .
I agree if this is going to be done you must have a DPDT switch to make sure there is no power to the other equipment .
The heater only getting warm sounds to me like either it is now operating on 120 volts instead of 240 volts, or the two heaters are now in series with each other.
Either way a 240 volt heater operating on 120 volts or in series ( IF THEY ARE BOTH THE SAME WATTAGE) only puts out 25% of its normal heat.
That could explain why the heater was only getting warm.
I am not sure of the legality of this arrangement.
bbadger wrote:
FWIW the NEC would not require a double pole switch for this.
The switch would be a controller not a disconnect, controllers do not have to break all poles.
It is common to use a single pole thermostat (another type of controller) with 240 volt baseboard.
I know that they use singe poles for some electric heaters . In this case they are also trying to feed an AC from the same circuit . I do not like it but if I was doing it I would want to isolate the Heater from the circuit.
