Roof damage to asphalt shingles can come in a variety of manners. The photo uploaded shows a roof shingle that has completely detached. I would classify this a functional damage. This type of functional damage would likely have been caused by wind.
Flashing is visible but may not be counter flashing with a sub-layer of flashing underneath. Sealant was used to bond the flashing to the roof covering material. Instead, step flashing should be visible with counter-flashing overhanging, imbedded into the mortar joint and sealed.
I read an article regarding the legal ramifications of declaring yourself an expert. By calling yourself an expert, you are legally holding yourself to a higher standard. There are many other ways to promote yourself other than calling yourself an expert – including being knowledgeable.
Many homeowners and home occupants aren’t obviously aware of the many ways to save energy in a home. There are several reasons to adopt a more conservative approach to household and appliance use and operation. First, it saves money. The government periodically gives rebates for low energy consumption. It is also less taxing on the environments natural resources. In almost everything we do as consumers, there is likely a more conservative approach that will save energy and costs, while getting the job done just as well just by giving things a little more thought.
From the picture,The roof covering is asphalt composition singles.I see cosmetic issues with the trees touching the roof.On some of the shingles,the volatiles has been scraped off and the shingles looks age.Shrubs any greenery touching the house promote fast decay.
How a credit report works.There are three major credit bureaus Equifax,Transunion,Experian.These three bureaus take all your credit history gather from smaller bureaus,about your debt,pay history,and if you pay on time.Based on your credit report lenders will decide if your high credit risk or how much the bank will loan you.
In the article titled, Mastering Roof Inspections:Asphalt Composition Shingles, Part 11, I learned the two categories of damage. They are functional and cosmetic. Functional is when the damage diminishes the ability to of the roof to shed water or shortens it’s long term life. Cosmetic damage problems are discoloration, color blending or anything does doesn’t meet the definition of functional damage. Insurance companies pay for functional but do not pay for cosmetic.
Image result for roof damage from hail
As an example, hail damage to asphalt and composition shingles can look very different than hail damage to wood shingles. It is important to know the different effects of the damage to properly identify whether or not you have roof damage from hail. Loss of granules, which may expose the roof felt.
This is a picture of a roof with architectural asphalt shingles. The roof overall looked to be in good condition. The shingles are approximately 15 years old and are aging as expected. This picture is from the eave to show there is a rise approximately 3 feet in diameter in the roof which could slow the flow of water and result in water intrusion. Also noted that the vent stack is only extending through the roof 3 1/2 inches. Recommend a licensed professional to further evaluate.
this shingles on this home appear to be in good condition. look closer and the roof sheathing was to thin and sagged under the weight of the shingles the spot was also soft, going into the attic showed that there was previous moisture intrusion.
Adjustable steel columns:
Steel columns are powder painted with rust resistant paint. They are out of the scope of a typical home inspector but they may refer there client to a engineer architect to check for any concerns that the home inspector has.
This is a picture of the roof section of my house! The valley is a closed valley with only shingles showing! There are architectural style shingles installed which is a much better shingle than the standard ones! The drip edge is installed correctly and the headwall flashing!
One thing I have learned since I have joined Internachi and have been taking different courses is that Moisture is a bad Dude!! Moisture creates mold, rot, corrosion, cosmetic damage, interior damage, illness, bad indoor air quality and much more!!
This is a 3-tab asphalt shingle roof system. This picture reveals a missing shingle. Also it depicts ventilation projecting through the roof but with missing flashing. around the vents it seems someone used a sealant which possibly could cause future default in the roofing system.
After reading mastering roof inspections part 3. it details that applying a radiant barrier to the rafters will increase hot air in the attic. in contrast, by connecting these barriers to the attic floor, the amount of radiated heat will decrease into the living space and the attic would still be ventilated.
Pictured here is a asphalt shingle roof. It is a laminated shingle and appears to be in good condition. There are no missing tabs and there is no apparent damage from hail or any other strikes. The aggregate is in good condition and overall color is good.
Moisture comes in liquid, solid, and vapor forms and can be damaging to shingle roofs. Liquid which is from rain can wash away granules, get under shingles through damage or improper flashing and cause damage to the sheathing. Solid moisture or ice can cause ice dams which will back melted water under the roof covering. Forms of vapor or gas come from inside the home via washing clothes, bathing, cooking etc. The vapor can cause damage if it is not vented properly.
This picture shows an architectural style asphalt shingle roof. The lower roof has a darkened area in the middle lower portion. There are no overhanging trees and no debris. It is not soft or wet so it is likely a lack of maintenance versus moisture issues.
two types of damage. Though the blister appears deeper the damage isn’t quite as severe as hail since hail (in this image) split the mat. This would be more likely to cause a leak than the blister though both are of concern and though a blister over time can be susceptible to leaking as well.
