I’m not going to wallow through this thread because this ventilation issue was covered by reporting the blocked roof ventilation (which is the primary cause of the elevated moisture, not the bath vents).
It is not the inspectors job to analyze or determine what and how something must be corrected.
Post where your state requires this reporting in the Home Inspection Law.
Do you have a law? If not, your “Understanding” is the same as the Code which likely did not exist either!
