I believe that STC ratings that you are interested in might be found here.
bJones is on the right track.
http://www.stcratings.com/header.jpg
[size=3]STC RATINGS FOR VARIOUS WALL ASSEMBLIES
Below are the STC ratings of various wall assemblies, each presented to help illustrate concepts, improvements and rules of thumb. The estimated ratings are based on laboratory test results from various compendiums of STC ratings. It is recommended to consult a professional acoustician for more detailed information or to analyze the specifics of your project/assembly.
To view different wall assemblies, click on each point below that may apply to your project.
- Insulation will noticeably improve the STC rating of an assembly.](http://www.stcratings.com/assemblies.html#01)
- Staggered or double stud walls are higher rated than single stud walls.
- Metal stud walls perform better than wood stud walls.
- Resilient channel can improve the STC rating of an assembly.
- Adding additional layers of drywall can improve the STC rating of an assembly.
- Drywall between double studs can dramatically reduce the STC rating of an assembly.
1. Insulation will noticeably improve the STC rating of an assembly.
Description
Estimated STC Rating
Wall Assembly
3 5/8" metal studs, 5/8" gyp (2 layers total), No insulation
38 - 40
3 5/8" metal studs, 5/8" gyp (2 layers total), Batt insulation
43 - 44
[FONT=Arial, Helvetica, sans-serif]back to top](http://www.stcratings.com/assemblies.html#top)
2. Staggered or double stud walls are higher rated than single stud walls.
Description
Wall Assembly
2x4 stud, 5/8" gyp (2 layers total),
Batt insulation
34 - 39
Staggered studs, 5/8" gyp (2 layers total),
Batt insulation
46 - 47
2x4 studs, 5/8" gyp (2 layers total),
Batt insulation
56 - 59
back to top
3. Metal stud walls perform better than wood stud walls.
(NOTE: This only applies to single stud assemblies. For double stud assemblies, there is virtually no difference.)
Description
Wall Assembly
2x4 stud, 5/8" gyp (2 layers total), Batt insulation
34 - 39
43 - 44
back to top
4. Resilient channel can improve the STC rating of an assembly.
(NOTE: These ratings are based on laboratory tests. Because of the special care required when installing resilient channels, actual results could be substantially lower.)
Description
Wall Assembly
34 - 39
2x4 stud, 5/8" gyp (2 layers total), Resilient Channel, Batt insulation
45 - 52
back to top
5. Adding additional layers of drywall can improve the STC rating of an assembly.
Description
Wall Assembly
34 - 39
3 5/8" metal studs, 5/8" gyp (3 layers total), Batt insulation
39 - 40
2x4 stud, 5/8" gyp (4 layers total), Batt insulation
43 - 45
back to top
6. Drywall between double studs can dramatically reduce the STC rating of an assembly.
Description
Wall Assembly
2x4 studs, 5/8" gyp (4 layers total), Batt insulation
44 - 45
2x4 studs, 5/8" gyp (2 layers total), Batt insulation
56 - 59
2x4 studs,5/8" gyp (3 layers total), Batt insulation
59 - 60
58 - 63
back to top
Rules of Thumb
Recommended Ratings
Weaknesses - What You Should Know
The difference between STC and NRC
STC Ratings for Masonry Walls
Marcel
[/FONT]
[/size]
