I was just curious, during an inspection, if you see low levels of insulation in the attic (I have seen houses with no attic insulation), do you recommend additional insulation?
Whenever I see this, I discuss that with the client, but, I am just not sure the best way to write that up.
I do comment of poor or missing insulation. I basically state the problems and that they don’t meet current standards. I state the home could be using more energy that a house that is properly insulated. Resnet uses grades 1,2,&3 to evaluate how insulation is installed. Most of the time it is Grade 3. Grade 1 is perfect and almost never happens.
We inspected a 5 year old home that had sold 3 times and
number 4 was the first to have an inspection .
Zero insulation in the attic .
I guess all the rest could not afford the heating Bill
3-4 Inches = approx. R12.
This is considered low for an attic space. When the home was built an R=12 insulation was considered adequate. We now know that increasing the insulation value can save on fuel and make the home a more comfortable living space. An R=40(Approximately 14-16" of blown in insulation) is recommended. Consider adding more insulation for improved thermal efficiency.
Make sure if you are going to put this kind of statement in that you also talk about proper venting. In my HI report i have a seperate section for ventilation where I explain how to get proper venting in the home when they increase the insulation.
I just saw another property on Friday that had missing insulation in a bedroom whose common wall was to the attached garage. Hopefully, the investor will fix that before he re-lists the property after his renovations.
