From yesterdays inspection. 1980 construction but this addition was added much later, late 90s-early 2000.
Argon gas problem?
Broken seal on patio door. The center of the door is sucked in showing colder temp.
Good image Russel.
Yep - good image.
Run it through Quick report or FLIR tools to upscale it and remove extraneous water mark and point measurement tool then publish to your website.
I will chuck, here are a few more from the same house. The last two are skylights. I like the last one where there is partial failure next to full failure.
I never see them here
Yep…my house was built in 1981 and we’re in the midst of replacing them all.
2/3 of the way through and $21,000 later…
Jeff
