Interior panel
Originally Posted By: jpope
This was the original fused panel (in a closet) that had been replaced by a new exterior panel. All of the splices were made in this shell.
![](upload://5lUZH8uyla6RqSlf0JSKA4U5Wyo.jpeg)
Other than how it looks, is there anything wrong with this practice? There were no open knock-outs and the box appeared solid.
![](upload://e0VmrSW2u3DC5nMDe5pPqqMiobW.jpeg)
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: jschwartz1
It appears someone made this a junction box and pulled the wires to the exterior panel like you mentioned. I would recommend the buyer get a copy of all permits pulled on the property and include them as a part of the sellers diclosure statement.
Originally Posted By: Kenneth Sitzes
Hi,
That the way it is done in this part of this state. They are inspected an approved by the city inspector here.
Originally Posted By: rmoore
Jeff…
This came up in another thread some time ago and I'm almost certain that one of our in house sparkies said that there should be a blank plate firmly attached. In other words, the hinged door by itself does not offer adequate protection against access. Think about children coming across this!
The one in your photo looks like it is keyed? I think that would be OK as long as the key wasn't left in it.
Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Jeff Pope
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: psmothers
http://www.nachi.org/bbsystem/usrimages/more/100_16291.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/more/100_16301.JPG ]
Foxe Smothers
"Its not a matter of will we rebuilt it is matter of how soon..."
"A hero is no braver than an ordinary man, but he is brave five minutes longer."
- Ralph Waldo Emerson
Originally Posted By: dvalley
Richard,
Are you sure about the hinged door? I wasn't aware that this panel (containing splices) had to have a secured cover installed over this.
Please confirm.
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: bbadger
I can not find any requirements to screw the cover on.
I can even buy large junction boxes with hinged covers.
That said from a safety standpoint I would and have screwed panel covers shut used like this.
Bob Badger
Electrical Construction & Maintenance
Moderator at ECN
Thank you Bob. I learn something new every day.
I'll start mentioning that these specific junctions need screw-on covers.
David Valley
MAB Member
Originally Posted By: jmertins
I do not think the distance around the box with regards to obstructions meets codes.
If it still had breakers in it you would be correct, as a junction box it is all set.
They have not yet required work space rules at junction boxes.
Bob Badger
Moderator at ECN
Originally Posted By: jpeck
Bob,
Your large hinged junction box is listed that way.
This box was listed with a dead front cover (with breaker or fuses blocking the 'openings' in the dead front cover.
That dead front cover was removed with the 'panelboard'. The 'enclosure' was likely listed for use WITH the dead front cover.
I'd want to see a piece of sheet metal screwed in place over the opening.
To me, screwing the hinged cover in place does not take care of that as well as installing a dead front front cover.
Jerry Peck
South Florida
Wouldn't that sheet metal need to be listed as well?
Jeff Pope
(661) 212-0738
jpeck wrote:
Bob,
Then when you get there write it up that way. ![icon_smile.gif](upload://b6iczyK1ETUUqRUc4PAkX83GF2O.gif)
Of course the sheet metal you ask for would be a listing problem also, as Jeff pointed out.
Luckily you are not an electrical inspector here in MA this is a common way of dealing with panel relocations. Permits, inspections and all.
Bob
Bob Badger
Moderator at ECN
As compared to the unlisted 'air' in the opening? ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
Jerry Peck
South Florida
Originally Posted By: tallen
That J- box needs no screw! You guys are nuts, I would recomend a screw or something , but it is not required.
Code Shmode! (at least in this case)
Personally, I see nothing wrong with using the box as Jeff pictured, but I am concerned about children's wandering fingers when access is as easy as this one looks. So screws, epoxy, a lock, or even duct tape...just as long as the interior is not accessed by simply opening an inviting hinged door.
I'd write it up as a "Safety Concern", explain my concern, and then leave it up to the client.
BTW...is that big metal box still bonded to the grounding system?
Richard Moore
Seattle, WA
www.rainspect.com
Jerry what 'air' are you talking about?
Cover closed = no openings.
Sometimes I think you just want to disagree. ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
Now if past history holds true you will likely reply with 2000+ words. ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
By the way. under the 2002 NEC there is no requirement to close unused breaker spaces.
There was previously and I believe there will be again under the 2005.
Bob Badger
Moderator at ECN
Originally Posted By: Jeff G. Hooper
This section covers it. 110-17. Guarding of Live Parts (600 Volts, Nominal, or Less).
Still in the code.
Sorry, not 110-17 in 2002.
Try 110-12. Mechanical Execution of Work.
(a) Unused Openings.
