I was wondering if anyone knew of a tool, exact name please, for determining the size of a wire for instances where no lable is visible? Some of these 4, 6 and 8 get hard to tell apart, especially in older wiring or wires with thicker insulation.
I have been searching the internet and I can’t find anything.
Until they are comfortable guaging wire some inspectors will go somewhere (big Box store< etc.) and buy a short piece of each wire size with the size on it to carry with them on inspections.
Hi Larry, you must have sat in on one of my classes as that is just what I teach. wire guages are available but after many years of hearing horror stories of wires detaching from breakers and breakers becoming detached from busses I stopped recommending them.
I have carried samples for years just in case. I’m pretty good at wire sizing, however sometimes, even with samples in hand, it gets difficult. I currently have to figure out if a wire is #4 or #6. The wire is about 30 years old and has very thick insulation which makes it look a lot bigger than it is.
Anyhow, I was hoping there is some sort of tool for helping with the sizing.
The only SURE way to get it right is with practice and experience. The slip over or side guages simply can be wrong as insulation varies from type to type. The best method is to visit the supply house or supply store and get familiar with the different sizes…and I STRONGLY suggest making a CHEAT tool as Micheal has made…really helps you visually when looking in the enclosure.
Good advice, I noticed one guy pull out a 4" aluminum disk, with notches cut into it, and he went diving into a hot panel to ‘gauge’ live wires. I dove out of the room.
As you can see you need to slide it over the bare conductor. With live breakers, and close together, you can short out several wires at one. Wow what a pretty shade of blue.
