gallen1
(Gregory Allen, NC #2239)
February 22, 2006, 12:54am
Can you guys give me your opinion on this pipe,is it polybutylene?House was built in 1994.
jhagarty
(Joseph Hagarty, CMI)
February 22, 2006, 2:01am
3
PB 2110
Look closer at the piping to determine the proper nomenclature as each is properly marked.
If PB2110, recommend replacement of all interior piping.
gallen1
February 22, 2006, 2:36am
4
Thanks a bunch I looked closer and found a PB2100 on the pipe.
rray
(Russel Ray)
February 22, 2006, 2:57pm
5
jhagarty:
PB 2110
There still is quite a lot of confusion and debate about PB2110, especially if the connections are metal (usually brass) like that shown in the picture. I think a better recommendation would be to consult with a licensed plumbing professional since they are still fighting about whether or not all PB2110 needs to be replaced.
rray
(Russel Ray)
February 22, 2006, 3:00pm
6
Went to get the references.
Here’s what I put in my report:
**Attic—Active water supply pipes in attic appeared to be polybutylene plastic (hereafter, “PB”). **Although evidence appears to be inconclusive, it is believed that chlorine and fluorine react with PB, causing pipes to scale, flake, and become brittle. Micro‑fractures can result, and the basic structural integrity of the system can be reduced, thereby becoming weak and possibly leaking without warning. A home inspection cannot determine if PB water supply pipes are about to leak simply by looking at the outside of the pipes since they apparently deteriorate from the inside, and they can split or burst under pressure at any time. Insurance companies are known to decline to offer insurance on homes with PB water supply pipes because of associated problems with it. For helpful information about PB pipes and a class-action lawsuit, click here](http://www.usinspect.com/car/1203plumbingpb.asp ), click here](http://www.polybutylene.com/ ), and click here](http://www.pbpipe.com/index1.htm ). Recommend further evaluation by a licensed plumbing professional before close of escrow.
