I came across this wire today, that looks like an old fashion K&T but it is slightly different - it has a woven / snakeskin sheathing over single, insulated conductor.
I would like to know the exact mane of this type of wire. It is technically not a knob and tube [or is it?] as it is not utilizing knobs or ceramic tubes, but the sheathing is a NM snakeskin tube over single, insulated copper conductor. Appears to be box to box - no knobs, tubes or an exposed wire
Anybody knows the exact name, and what are the safety issues if any with this type of wiring?
Thanks
Looks like someone spliced off the K&T at one time. The covering you see is often used when the wire enters a box. This should be evaluated by an electrician.
It’s not K&T. And how do you know the number of conductors in the cable?
Did you touch the insulation to see if it’s still effective?
Is that what you do Joe??
I opened the J box and the insulation was still good - I still do not know if it is considered K&T. I do not want to make an unsafe claim if it isn’t
Frank this link will help you identify it.http://inspectapedia.com/electric/Knob_and_Tube_Wiring.htm
Are you sure about that?
Looks like the loom that was used with K&T.
Yep.
http://www.nachi.org/forum/data:image/jpeg;base64,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
That is knob and tube, did a house just like it sunday, if you follow it it will spread out and into knobs and tubes. They use that covering when they go up thru floors in a tight spot. Make sure you suggest at least GFCI protection and that a qualified electrician evaluate the entire dwelling for incorrect conditions, and they always exist somewhere. Make sure insulation does not cover this wiring as it needs to be air cooled.
Well, after reading other posts I suppose it could be. But anytime I’ve suspected K&T I’ve seen K&T somewhere (attics or crawl spaces). Not sure I would call it out as K&T if I didn’t see it, but only suspected it.
What else could it be but K&T if the individual conductors entered through different knockouts? Any method after K&T was a cable type assembly except where gas pipe was retrofitted.
Easy enough to confirm by removing the junction box cover.
When I reno’d my house I had this exact wiring. There was k &t elsewhere (just the tubes) but I followed it and it wasn’t part of it. I believe this was the next generation after knob and tube. Until you find the knobs and tubes I wouldn’t write it up. But if its like mine it is very brittle and should be replaced anyway.
This covering is used extensively in areas where the K+T single strand may need protection but not support. Seeing no knobs and tubes on such a small exposed section of wires does not negate that it is K+T!
Call it what it is.
Wrong. The loom sleeving (pictured) is part of the knob & tube system.
http://www.nachi.org/forum/data:image/jpeg;base64,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
