Laundry exhaust fan ALWAYS On
Micheal, was there a heat or energy recovery ventilation system?
If so post the model number please. As well sensor wiring on the cabinet harness.
Where there any sensors on the wall? Pics if there were please.
Many times air tight homes require CFM air exchange.
Typically/usually even a duct with inline fan can be tied into the HRV/ERV system.
I take images of the exterior ducts.
Count the bathroom/s, HRV/ERV and subtract the vent wall ducts. One extra wall exhaust duct is typically an inline venting system.
Request disclosure from the vender.
Talk about Old Fart, you had to bring Roy Cooke’s name up…
We’ve finally come full circle with energy efficiency…Now we’ll suffocate if we don’t draw in some fresh air…
We also no longer trust people to have enough sense to crack a window open :expressionless: :scream_cat:
You talkin’ about the faker who was expelled from this organization once… … …
Robert, these homes had none of the things you mentioned here. Sorry…
Apparently… on good weather days letting the house “air out” by opening several windows is usually pleasant… IMO anyway… :smiley:
That is the one!
You know that when one (OLD FART) leave, there is always another to take over and that is where Young fits in…
Thank you, Micheal.
Usually on the homes that i find that have a continuous fan will have a switch located under the cover on the fan itself that the homeowner can have control over, i have yet to find one that does not have this option but there may be some that don’t
I learned something today. Thank you. I’m down with the constant fan, here in SoCal everyone is super envioro-crazy and LEED is common, however I have not seen this in practice yet. When I do, I’ll know how to explain it to my clients. It will actually be a benefit for them.
Michael, Next time you’re at one of these, take the cover down. You’ll find 2 adjustments or controls. One for speed and one for time. Here’s how it works: The fan is on all the time at the lower speed. The switch steps the speed up to the pre-set 2nd speed. But if the pre set is set to low, there won’t be any change. If you adjust that control you’ll see the change. Its a soft start type so the speed change will be gradual. (It’ll take 15-20 seconds)
Then, turn the switch off. The speed stays high for a pre-se amount of time. That’s the 2nd control.
That’s why the fan behavior is what it is. I’ll let others comment on the good or bad of having such a system, but a laundry exhaust fan is required by most of our local AHJ’s around here. And that’s the type they install.
Good to know thank you
I will check that out on the next go around. Thanks for the info.
