Leaning chimney?
Saw this in an attic today and not sure what or if I should comment. Has anyone else seen a leaning chimney made of cinder blocks? It was obviously designed this way intentionally so that it penetrated the center line of the roof. The component is supported by 2 2x4 beams the run along the underside of the chimney.
Look up “Witches Bend” or “Witches Crook”.
Yes this actually pretty normal, I was a mason in Connecticut for 18 years and I saw quite a few chimneys similar to that, I even built some but I would always step the level block towards the opening, never tilting them like in the picture
Definitely some type of wizard spell or magic holding that one up!
OP has a witches bend! This is a leaning chimney!
Concrete pad under the fireplace had fallen away from the house. Entire fireplace and chimney pulled away with it. Repair was to remove the fireplace entirely and patch the wall.
Morning, Bob.
You sure that is not a chimney shoulder? There are 2 shoulders on that chimney. The bricks are raked >< 45 degrees.
You mention the concrete pad is degraded. You sure the pad is not the 4" hearth for the fireplace/chimney? For the concrete pad/hearth to fall away would have the bricks settle over time.
Just asking.
I concur that chimney’s mortar is in poor shape.
