Use extreme care when removing painted over covers.
This panel was painted over many times.
I scored around it with a knife.
I did not notice a “patch” that had been applied to the bottom left corner.(see attachment)
After scoring with knife I removed the cover.
Taking with the panel a chunk of the patch with it.(see attachment)
I still remove covers if they are safe to do so (no standing water etc.) But I make damn sure not to damage anything in the process. Learn from my f ups.
I have had a few where they smoothed it into the wall like that .
Best to let them know the wall will get damaged ahead of time if you catch it of course.
Recommendation for inspectors is to get what is referred to as a B knife.If you can not find one in a store talk to your phone guy.
why is that a mistake. The wall can be fixed. An electrician would do the same thing if he had to get into that box. If there is a chance the wall will get ruined I always ask the seller before taking the box off. Twice in nine years they have requested that I do not remove the cover.
You’re forgetting about the inspector who has convinced himself that he can plug the drain to the shower and fill it in order to test the pan, send water to the ceiling of the finished area below the shower, and simply walk away reporting that it “failed under test”.
