Let's discuss the attic and basements areas
Let’s discuss the attic and basements areas and what we find wrong when inspecting the electrical systems.
Originally Posted By: cradan
, most commonly-found:
*Completely unenclosed branch wiring connections
*Open junction boxes
*Unsupported and/or unprotected NM
Basements, most commonly-found:
*Same as attics
*Disconnected bonding straps and grounding electrode conductors at metallic water service entry piping
*Lack of GFCI's
Chris
http://www.inspect4me.com
Chicago Illinois Home Inspections
Originally Posted By: jjackson
Also, in the basement is usually were I find the panelboxes. Here we have double taps and double lugged neutrals, inadequate access to panel, improper gounding and bonding. Also, in sub panels, the absence of a floating neutral-the neutral is grounded right to the box.
jj
Originally Posted By: wdecker
I usually call out any water carrying device if it is not GFCI protected, like sump and ejector pumps or water pressure boost pumps.
In attics, I see a lot of sub standard (most, times, just zip cord) used to run new service to ceiling fans and can lights. Note: Around here, only wire in EMT or some kind of rigid metal conduit is allowed. Not my rule, theirs.
Will Decker
Decker Home Services
Skokie, IL 60076
[email protected]
Originally Posted By: jmurray
“A little less conversation and a little more action”!
Originally Posted By: mgault
-Mike
A to Z Home Inspections, LLC
www.atozhomeinspections.net
Originally Posted By: lewens
Don’t forget my personal favorite, Knob and Tube buried in 8" of insulation in the attic.
Just my usual 12.5 cents
From The Great White North Eh?
NACHI-CAN
www.aciss-brant.com
www.certifiedadulttrainingservices.com/
Couldn’t see it without moving said insulation…
-Mike
