As does the internet!!
Tapinspect has a per inspection report fee you might consider looking into.
and it can also crawl the web and copy any narratives it finds if it is so instructed. and all it has to do is give me 1000 narratives to do some work on and i have 1000 i didn’t have to write. i can tweak a lot quicker than coming up with unique things. it may not work that well at all, i have yet to try it. i know it writes code pretty well.
The best narratives are those you write yourself. Too many inspectors don’t understand the narratives they copy and paste or have AI write for them.
that was my main reason for writing my own reports and not using software. it just takes longer to automate it unless i sit and write narratives for days, which is not a terrible idea for spare time work that is usually spent on the computer reading. the only downside i can think of is if the ai grabs narratives from reports that used software and copyrighted the narratives. of course changing the wording would solve that but writing my own avoids it altogether, which is the path i have taken so far. i may give the ai a go while snowed in today.
Here is a ChatGPT response. First is my input. Second is the output.
I write my narrative and run it through the machine for ideas. It really cannot be trusted any other way. Even then, it changes things, so be careful. A small change can have considerable implications.
Look how it changed the tile statement. The tile is a slip hazard, but that is only one of the issues, not the result of the other issues.
Input:
improve
Per the General Manager Ms. Banks the 2nd floor exterior concrete walkways have been and continue to be an issue. She stated the tile is cracking, failing, and is a slip hazard, and the surface coating is failing in select areas.
ChatGPT output
According to the General Manager, Ms. Banks, the 2nd-floor exterior concrete walkways have been and remain problematic. She reported that the tile is cracking and failing, creating a slip hazard, while the surface coating is deteriorating in certain areas.
i appreciate it. i think you had a problem with the prompt. i used your original text and this prompt: as a licensed home inspector in wv, can you improve the following narrative od a defect found? it should keep the same meaning that it has now but sound more polished and use past tense and third person speech.
this is what it gave me: According to General Manager Ms. Banks, the second-floor exterior concrete walkways had been an ongoing concern. She indicated that the tile had cracked and failed, creating a slip hazard, and that the surface coating had also failed in select areas.
it sounds a little better and kept the same meaning, at least it sounds like it to me. then i used this prompt: that is better but doesn’t sound professional enough. can you improve it?
and it said: According to General Manager Ms. Banks, the second-floor exterior concrete walkways had been a persistent issue. She reported that the tile had cracked and failed, posing a slip hazard, and that the surface coating had also deteriorated in select areas.
i have yet to get new narratives from it but it does a decent job at cleaning it up if you use a thorough prompt. i put a report through and it took it from abut 18 pages of text to 7, changed evertyhing and did a terrible job. looked good though just lost a lot of what i was trying to convey.
Agreed. I just want people to be very careful. I do not recommend getting narratives from ChatGPT. It will likely regurgitate some other inspector’s mistakes.
As noted before, the same issue persists with the ChatGPT edit.
The ChatGPT edit text implies that tile cracking and failing creates a slip hazard, which is incorrect. The problem with the tile is three separate issues. Cracking. Failing. Slip hazard.
(just as a side note: I do not use past tense in my commercial reports).
It gets to know you. Chat GPT knows I am an inspector, lol.
My experience with AI like Chat GPT is that it is more like Artificial Unintelligence.
Many years ago in the infancy of electronic reporting, I wrote up my own Word based report and have used it ever since. I have over a couple hundred hours invested in it over the years, but I like it, and most clients and real estate agents either like it or don’t object. And I am not held hostage by any software company.
I tell newbies, “Stick with companies that have been around at least 5 years, because most companies are gone within that time.” The home inspector market is tiny and it doesn’t take many service providers to end up getting only small slices of the home inspector pie.
Hey Barry, I still use HIP desktop version 6 on a Microsoft Surface Pro 7. No transferring files from tablet to PC, all you need to do is load up your pics to the Surface and complete your and send your report all on one device.
i did not notice that, thanx. yeah, it isn’t good at a lot of things but it has it’s moments. i’d rather write my own to avoid getting copyrighted ones and ending up in trouble. i was told it was better to use past tense and third person, but that is for residential. is that not a good idea?
Past tense for residential narratives is the standard and a good idea. I believe it is based on the fact that conditions change, and the narrative describes a snapshot-in-time from the past. Therefore, current conditions do not apply.
why the change in commercial then? is it not also a snapshot in time from the past and conditions change there as well?
In a nutshell, the standard of practice I use for commercial inspections directs or informs the end user how to use the PCR (property condition report). Here is an example of such verbiage.
A specific point in time - A user should only rely on the PCR for the point in time at which the consultant’s observations and research were conducted.
The typical home inspection standards of practice do not contain this instruction or guidance for the end user.
