This Siemens Panel had the 100 Amp, 240 volt main disconnect breaker crammed into the wrong size cutout. The bottom panel was covering the bottom of the breaker. It is a siemens brand breaker just like the panel but it doesn’t look like it fits right. I took a temp reading with my gun and it was the same temperature as the other breakers. My opinion is that it is the wrong breaker for this panel and a electrician should be consulted to change it.
Catalog Number?
Appears to be, SIEMENS 100A Electrical Panel with 24 Circuits Expandable to 48 circuits. Cat No: PW1224B1100CU. Remember, appears to be.
Observation: Poor Main Breaker or Panel Front alignment affecting the main disconnect and the 15 amp breaker in slot A3B. Recommend: Further review and correction by a licensed electrical contractor.
Mr. Goldenberg. I do not dismount electrical panel fronts.
You are truly unprofessional in your actions on the MB.
I have no beef with you. Kindly put me on ignore.
Members. Mr. Goldenberg is not trust worthy. His actions speak for themselves.
NTBT: Not To Be Trusted.
Your 100 Amp Main Breaker is 2 inches wide but the areal that goes in the open space in the steel cover is a little smaller About a 16th of an inch on both sides are recessed a little. I always suggest using an electrician period but if you are not afraid, loosen the screws that hold the steel cover, make sure the breaker is pushed down all the way and align it properly. it may need a little push to the side. Your main breaker is the correct one for 100 Amp. With a little push, you will be able to get the cover on correctly
