MANABLOC - PEX
Originally Posted By: jburkeson
All,
This was my first experience inspecting this type of plumbing installation, thought I would post what I discovered to help others.
[ Image:
http://www.nachi.org/bbsystem/usrimages/more/IMG_0007.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/more/IMG_0006.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/more/IMG_0024.JPG ]
Here are some manufacturers links to study;
http://www.vanguardpipe.com/mbloc.html
http://www.vanguardpipe.com/mbloctech.html
When I first arrived on site I thought that I was dealing with PB, that was not the case as the pipe is clearly marked PEX (Cross-Linked Polythene) In any case, it would seem that MANABLOC - PEX is the answer and remedy to PB piping, it is rated 100 PSI @ 180 Deg F. This particular installation was 9 years old operating flawlessly without leaking.
Joseph Burkeson, RPI (Hooperette)
?Anyone who has proclaimed violence his method inexorably must choose lying as his principle.?
~ Aleksandr Solzhenitsyn
Originally Posted By: Blaine Wiley
Originally Posted By: David Suelflow
This is what I say:
Subject home has cross linked polyethylene (PEX) supply pipes. This pipe has replaced the controversial Polybutylene (PB) piping which is a plastic supply piping system with a history of premature leakage and has lost judgements in class action lawsuits. PEX piping has been used in Europe for years without problems but is too new in the USA to have conclusive data. It is the current standard in plastic supply systems.
A good article on PEX can be found at:
http://www.ppfahome.org/pex/faqpex.html
or at:
http://www.pmmag.com/pm/cda/articleinformation/features/bnp__features__item/0,2379,90757,00.html.
For further information you can call the Consumer Plumbing Recovery Center at 1-800-392-7591 or on the Internet at http://www.pbpipe.com.
Originally Posted By: phinsperger
David Suelflow wrote:
... This pipe has replaced the controversial Polybutylene (PB) piping which is a plastic supply piping system with a history of premature leakage and has lost judgements in class action lawsuits....
David,
Just wondering why you would mention Polybutylene at all when discussing Pex. PB and Pex are different products. If the subject were say... wiring, would you write something like;
Quote:
Subject home has non-metallic two conductor copper wire commonly known as Romex. This wiring has replaced the controversial knob and tube wire which is a older single conductor wire system with a history of causing fires. Romex wiring has been used for years without problems. It is the current standard in electrical wire systems.
The words the client will most focus on is "causing fires"
Pex may end up not being any better in the long run but until sufficient data has proven this I don't think we can take an alarmist view. I think a client reading your narrative 5 min later will remember only something like "plumbing - bad". Remember clients are reading (actually skimming) through your report to find out all the bad things.
Please don't think I am attacking your narrative. Its just kind of something that struck me as I read it and I am curious as why you included PB with a Pex narrative.
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
Originally Posted By: jpeck
Possibly because PB was the ‘next best thing’ and proved to be failure prone in many instances, and PEX is the ‘next best thing replacing the last best thing’, but do we really know how long it will last here? No, so advising your client that they have a relatively new to this market product is the prudent thing to do. You told your client that it is a new thing, replacing a ‘bad’ new thing, and that there is no enough history here to know how PEX will perform here.
Like seeing a 200 year old house and telling your client 'Well, this is certainly not the way we build houses nowadays, however, after 200 years of sustaining the current climatic conditions, it has passed the test of time, and we can only hope that newer houses will also be around long enough to pass the test of time.' You just told you client that it is not built to today's anything, and that might not be a bad thing.
Jerry Peck
South Florida
I guy I fight fires with put a pex system in his home… he said it was the slickest thing he’s ever used before. He installed it himself. With the manifold system and flexibility it’s really revolutionizing plumbing water supply in homes.
I am installing some as we speak.
Mike P.
Mike P.
Mike,
Hard to type and crimp at the same time? ![icon_smile.gif](upload://b6iczyK1ETUUqRUc4PAkX83GF2O.gif)
Jerry Peck
South Florida
Jerry
Yes. ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
It was in a commercial application where they where renting.
Any one could install this. It is just hard for someone from the 'old' school to try something new.
Mike P.
Originally Posted By: cmarshburn
I have yet to see pex in my neck of the woods but it does look interesting
Chris Marshburn
Marshburn Home Inspections
Originally Posted By: jhagarty
http://www.supplyht.com/CDA/ArticleInformation/news/news_item/0,5338,138543,00.html
http://enr.construction.com/news/bizLabor/archives/041129a.asp
Joseph Hagarty
HouseMaster / Main Line, PA
[email protected]
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Just replaced all the galv in my old farm house with PEX. Not one leak. icon_wink.gif
Paul Hinsperger
here !
