Microwave Oven Leak Tests
Originally Posted By: jtroth
Does anyone ever do these and if so how much is reasonable to charge for it?
Thanks
Talk to Jeff Pope. I know he uses some strange bar shaped object to test microwave ovens. Not sure he charges for it though
Originally Posted By: jpope
Standard part of the inspection. No extra charge. . .
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
what equipment do you use or prefer?
thanks
Originally Posted By: kelliott
I do them also as a regular part of the inspection. Mostly I’m testing built-ins. If its not a built-in I will ask the buyer, or realtor if present if it’s staying- usually it’s not, so they don’t care.
Originally Posted By: gporter
Part of the inspections. They are cheap to buy. Any home inspection equipment website carries them.
Gary Porter
GLP’s Home and Mold Inspections LLC
Orlando, Fl 32828
321-239-0621
www.homeandmoldinspections.com
Originally Posted By: jwilliams4
Professional Equipment has a “Magic Lights” - a plastic bar that
has dancing lights to show the microvave is operating. I guess it
beats boiling water.
"not just an inspection, but an education"
Originally Posted By: mboyett
http://www.nachi.org/bbsystem/usrimages/M/Microwave_Tester_002_Small4.jpg ]
Mike Boyett
Capital City Inspections
Austin, Tx
www.capcityinspections.com
I got mine here I think: http://www.professionalequipment.com/xq/ASP/qx/default.htm?keyword=microwave+tester I think it’s the MD 2000. It’s only problem is that if you carry it in your bag, you have to find a way to keep from mashing the button when you push it into the pocket in the bag. (The button is on the front) Or the battery is always dead. And it’s too much trouble to stop and take the battery in and out for every job. It’s got a small screw on the cover on the back.
Originally Posted By: bsumpter
The instructions that came with my magic bar said I must still use a cup of water…bummer
“In the fields of observation, chance favors only the mind that is prepared”
Louis Pasteur
