Milgard Vinyl Windows and Sliders
Shouldnt there be visible sealant between vinyl windows/sliders and stucco? From my understanding stucco shouldnt be touching vinyl windows/sliders.
Yes, should have gap and sealant over backer-rod. The backer-rod foam is the important “skillz” part of the job. The depth of the sealant needs to be fairly thin to allow it to stretch, instead of just pulling off one of the sides.
Looked at a house last week that was “well maintained” stucco with 2x4 trim on corners, windows, etc. Pretty sure it was built with raw wet wood and stuccoed before the wood could dry and shrink because there was big 1/4"+ gaps everywhere showing tar paper. House was about 40yrs old. I wouldn’t think about it without “destructive” tests for dryrot everywhere, which would be reasonable because “well maintained” meant it wouldn’t be a big loss to knock a 100 small holes in the drywall all over the house. Every house in the tract had same condition.
In almost all cases, and especially at windows, you want proper sealants or flashings used where differing materials come together. Different materials expand and contract at different rates, so without a flexible sealant, there will be a gap that can allow moisture and/or air penetration into the wall assembly.
In your picture, I would definitely want to see a high quality sealant used at that junction. My preferred exterior sealant is OSI Quad.
The only two exterior sealants I like are 100% silicone (any brand) and OSI Quad. Silicone is cheaper but can’t be painted, so it is not suitable for many applications, but can be used where painting (appearance) is not an issue. OSI Quad can be painted, so it is most suitable for exterior final caulking jobs. It also comes in a bunch of different colors.
so whats the fix? should they have installed j-casing or some type of metal casing around the door before install?
appreciate the response. ty!
In my opinion, you caulk it, using a high quality, flexible sealant.
On another note, stucco is abrasive, the vinyl windows should have been protected when applying the stucco,
