I believe the minimum allowable clearance from an exhaust vent termination above an operable window is 12". That sound right?
I have a 50 gal. conventional water heater in a garage vented out a side wall of a two story residence, the diagonal distance from the corner of the operable portion of the window to the vent is about 24".
Chris - thanks, I have that same image! It is a good one, I refer to it often. In this case though, the vent terminates above the operable window. Btw, how is the home-wizard working out for your business? Looks interesting.
Stephen - This is not direct vent, but a conventional Rheem water heater. I do not know the Btu, but suspect I could get it from the model #.
OK, if vent is above top of window opening and terminates at least 12" diagonally away from outside corner of window; that would classify as 12" vertically.
I have a client with a direct vent 2019 Amer Std H.E. furnace where the exhaust and intakes are about 2 ft below and to the right of a bedroom window. Some towns say they will defer to a manufacturer’s recommendations. I can’t get an answer out of Amer Std. Suggestions on this one??
