Venting near window
Originally Posted By: Greg Gillis
My neighbor just had a new hot water and furnace installed. It is a direct vent heater. It looks like they vented both right below the first floor kitchen window (maybe 3ft from the ground). I thought there would be some kind of code violation. We finally got some good neighbors and I want to make sure they are safe. Any thoughts? Thanks for your help.
Originally Posted By: away
Yes that does sound like a problem. The vent terminations should be at least 4’ below or to the side of operable windows.
Andrew Way
Keystone Residential Inspection Services PLLC
817.441.9598
www.keystoneinspections.com
Originally Posted By: rcloyd
Greg,
The required distance from the vent termination to a window opening will be found in the manufacturer's installation instructions (that came with the appliances).
Regards,
Russell G. Cloyd
Intra-Spec Home Inspections
& Code Consulting, LLC
859-586-4591
www.intra-spechomeinspections.com
