Minimum distance between Pex fittings
What is the minimum distance between Pex fittings? I seem two remember either 2" or two times outer diameter. These look very close together.
Thank you
Yes that’s a very good question every manufacture is going to be different. I prefer to use Uponor Pro PEX.
Too bad Martin, I stole your pex graphic. :grinning:
