Missing knockout bushing for ground
Ran into this today. This knockout bushing is missing here but the only thing coming thru is a copper ground. My instinct is to say this is ok. Am I out of line? Do you need a bushing just for the ground?
thanks.
There are typically small ko’s (about 1/4") for the entrance of a GEC into the panel enclosure. IMO when using a 1/2" KO the proper fitting should be used.
Agreed, ground should run through a 1/4" hole, other holes that do not have proper bushings or knockouts installed allow a path for vermin to enter panel and do damage.
Besides the Kenny clamp, what fitting is listed for that use? I know NM clamps are commonly used, but are not listed for the #6 or #4.
The Kenney clamp is the only listed fitting that I know of. I used two screw NM connector for years even though it’s not listed for a single conductor. Now we use the Kenney clamp or some generic version of it.
Thanks Robert. I had never heard of another option to the NM or the Kenny.
Oh no its a major defect. Everyone panic!!
