Mixed Fuels in a single flue
Originally Posted By: jhagarty
I am looking for the wording contained in NFPA 211 Section 5-8.
Particular concern is a Burnham Boiler that is a Coal / Wood / Oil Fired Boiler. Oil Burner on the right side with its own flue outlet and a Coal or Wood fired area with a Separate flue outlet.
These are then joined at a Tee into a Single Masonry Flue. I know it is wrong but I need the exact wording of the standard.
If anyone has the Particular wording or code, it would be greatly appreciated.
Joseph Hagarty
HouseMaster / Main Line, PA
[email protected]
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Originally Posted By: rpalac
Joe, I agree and these site might help. I didn’t have the correct code book with me, I even looked in my BOCA book but coul not find the right section.
The HVAC sites will definately point you in the right direction:
http://www.codecheck.com/mechcode.htm
No solid & gas/oil fuel in same vent [802.4] [n/a]
[UMC] 94' Uniform Mechanical Code by IAPMO
another source for info.
http://www.hvac-talk.com/gindex.asp
HVAC talk menue board
good luck,
Bob
